Parallel Plate Capacitor Question (Many Attempts)
The discussion revolves around solving a series of questions related to a parallel plate capacitor with specific dimensions and dielectric properties. The participant initially struggles with calculations for capacitance, charge, electric field, and energy stored, particularly at question vi regarding the new potential difference after removing the dielectric. Errors identified include incorrect exponent signs in capacitance, misapplication of formulas for voltage, and unit inconsistencies. After receiving feedback, the participant corrects their calculations and expresses gratitude for the assistance, noting improvements in understanding and accuracy. The conversation highlights the importance of careful unit management and formula application in capacitor-related problems.
MattNotrick
I have tried this set of questions which is from i-vii, I believe I am going wrong at a certain stage, as at question vi, the voltage is clearly wrong, below is the questions and my attempt. Sorry for the long post, any help on pointing out where I have gone wrong would be much appreciated, Thanks.
A parallel plate capacitor is constructed from two circular plates, radius 12cm and separated by a dieletric sheet with a thickness of 2 micro meters and relative permativity 6. The capacitor is charged to a potential difference of 110V
Questions
i) The area of one plate
ii) The capacitance
iii) The Charge on one plate
iv) The electric field between the plates
v) The energy stored in the capacitor
vi) The new potential difference if the dielectric is removed without changing the charge
vii) The plate separation is now changed to 1mm, find the energy compared to part v
Supplied within answers
i)Area = 0.0452m^2
ii)
c=εoεrA/d
C = (8.854x10^-12)(6)(0.0452) / (2x10^-6)
C=1.2x10^6F
iii)
Q=C/V
Q=(1.2x10^-6)(110)
Q=1.32x10^-4 C
iv)
E=v/d
E=110/2x10^-6
E=5.5x10^-5 J
v)
E=1/2CV^2
E=1/2(1.2x10^-6)(110)^2
E=7.26x10^-3 J
vi) (I feel I have gone wrong here, maybe earlier?)
I transpose C=Q/V to get V=C/Q to work out the new potential difference?
I need to work out the new capacitance with no dielectric so
C=(8.854x10^-12)(0.04522)/(2x10^-6)
C=2x10^-7 so
V=2x10^-7/1.32x10^-4
V= 1.51 x 10^-11
which surely cannot be right?
vii) (Need question vi correct to answer this one)
New capacitance = 2.4x10^-9
E=1/2CV^2
E=(2.4x10^-9)(Need answer from above)^2
E= Old Energy - New Energy
Thanks for anyone willling to help, Rick.
Questions
ii) The capacitance
i)Area = 0.0452m^2
ii)
c=εoεrA/d
C=1.2x10^6F
Okay up to here, but you missed the sign of the exponent in the capacitance above.
iii)
Q=C/V
Q=(1.2x10^-6)(110)
Q=1.32x10^-4 C
iv)
E=v/d
E=110/2x10^-6
E=5.5x10^-5 J
Watch your units. You divided volts (Joules/Coul) by distance (meters). Probably better to just leave the units as V/m.
v)
E=1/2CV^2
E=7.26x10^-3 J
Pretty much okay so far.
C=2x10^-7 so
You could simply have 'reversed' the effect of the relative permittivity of the dielectric by dividing the previous capacitance by it: C/\epsilon
V= 1.51 x 10^-11
You want V = Q/C, but you performed V = C/Q.
Are you sure that this new capacitor contains a dielectric?
{snip}
ii) C=1.2x10^6F should be C=1.2x10^-6F ... typing mistake
iii) Q = C/V should be Q = CV ... typing mistake
iv)
E=v/d ... correct
E=110/2x10^-6 ... correct
E=5.5x10^-5 J ... wrong! Be careful how you enter the numbers in your calculator. 110/2*(1x10^-6) is not the same as 110/(2x10^-6).
vi) "I transpose C=Q/V to get V=C/Q"
If you were solving for V you would get V = Q/C. And yes you are correct, when using the wrong formula (to get V= 1.51 x 10^-11), it surely cannot be right.
Clean it up and press on, you're doing rather well, just made a couple of silly mistakes.
Ok guys thanks for the quick and helpfull response (is there a rep+ button?) you pointed out some mistakes for me, I've gone on and finished the question, I am unsure of a few units though. Here it is from iv)
iv)
E=v/d
E=110/2x10^-6
E=5.5x10^7
v)
E=1/2CV^2
E=7.26x10^-3 J
vi) V=Q/C
C=2x10^-7 so
V=0.01452/(2x10^-7)
V= 72600
vii)
New capacitance = 4x10^-10 (no dielectric, thanks)
E=1/2CV^2
E=(2.4x10^-9)(72600)^2
E= 12.649824
12.649824-(7.26x10^-3)= 12.642564
Seems like quite a small change, thanks a lot for the help so far, been up late past few nights trying to do it alone
hows that so far??
iv)
E=v/d
E=110/2x10^-6
E=5.5x10^7
Units are V/m
v)
E=1/2CV^2
E=7.26x10^-3 J
vi) V=Q/C
C=2x10^-7 so
V=0.01452/(2x10^-7)
V= 72600
Your value for the charge looks suspicious. I recall that you calculated it correctly earlier. The units of V should be, well, V (Volts). Always put units on your results.
vii)
E=1/2CV^2
E= 12.649824
Check your values used in the energy calculation. That doesn't look like the capacitance value you just calculated (or even half of it). The unit of Energy is J.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
