Parametric curve question (determining unknown point)
cherry
A curve given parametrically by (x, y, z) = (3 - t, -1 - 3t^2, 2t + 2t^3). There is a unique point P on the curve with the property that the tangent line at P passes through the point (2, 8, 12). What are the coordinates of point P?
My work so far:
I am stuck because when I inputted the two possible values of t and k, neither solution worked. Where did I go wrong? Pointers would be appreciated! :)
cherry said:
Homework Statement: A curve given parametrically by (x, y, z) = (3 - t, -1 - 3t^2, 2t + 2t^3). There is a unique point P on the curve with the property that the tangent line at P passes through the point (2, 8, 12). What are the coordinates of point P?
Relevant Equations: (x, y, z) = (3 - t, -1 - 3t^2, 2t + 2t^3)
My work so far:
I see where I went wrong and it turns out t = -1 and k = 2 is the correct solution.
Where would I go from there to determine point P?
Hello @cherry, and
:welcome: ##\qquad## !​
Kudos for finding out!
is indeed 12, not 16. (*)
You have ##(x, y, z) = (3 - t\; , -1 - 3t^2\; , 2t + 2t^3) \ !##(*) quoting is a lot easier if ##\LaTeX## is used. See link to guide at lower left of edit window...
[edit] I didn't check if k=2 is the correct solution, nor whether the other solution is invalid
[edit] did now.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
