Parametric equations for particle motion
In summary, the motion of the particle with position (x,y) can be described as a circular path with a radius of 1, centered at the point (2,3). This can be visualized by plotting points on a graph or using a graphing calculator. The equations x=2+cost and y=3+sint represent this motion over the given interval of t being greater than or equal to 0 and less than or equal to 2 pi. The equations can also be rewritten as (x - 2)^2 + (y - 3)^2 = 1, which is the equation of a circle. Therefore, the particle moves in a circular motion, with the center of the circle being at the point (
jaidon
42
Describe the motion of the particle with position (x,y) as t varies over the given interval.
x=2+cost y=3+sint
where t is greater than or equal to 0 and less than or equal to 2 pi
i've tried to eliminate t and came up with
y=3+sin(arccos(x-2))
i don't know if this is even right, but if it is, I'm not too sure how to describe the motion. picking random points came up with a very strange graph. i am concerned because all of the other questions in this section had graphs which were circles or ellipses.
any advice?
All you have to do is describe the motion? Just plug in many different times and then plot it on graph paper. If the jump between two times is so great that you can not tell what happens between two points, then take another point with at time between the two other times. If you have a plotting program you can use that too. Some graphing calculators will do this too. However all you need is graphing paper and calculator with sin and cos.
x=2+cost y=3+sint
Rewrite the equations:
(x - 2) = cos(t)
(y - 3) = sin(t)
Square both sides:
(x - 2)^2 = cos^2(t)
(y - 3)^2 = sin^2(t)
Since both equations are true simultaneously, add them, and use {sin^2(t) + cos^2(t) = 1}:
(x - 2)^2 + (y - 3)^2 = cos^2(t) + sin^2(t)
Look familiar??
Path is Circle of Radius 1 Centered at (x=2, y=3)
Related to Parametric equations for particle motion
1. What are parametric equations for particle motion?
Parametric equations for particle motion are mathematical representations that describe the position, velocity, and acceleration of a particle in terms of time. They are commonly used in physics and engineering to model the movement of objects, such as projectiles, planets, or vehicles.
2. How do parametric equations differ from standard equations?
The main difference between parametric equations and standard equations is that parametric equations use a parameter, typically time, to describe the behavior of a variable over time. This allows for a more dynamic and flexible representation of motion, as the values of the variables can change continuously as the parameter changes.
3. What are the benefits of using parametric equations for particle motion?
Parametric equations offer several advantages over standard equations, such as being able to describe complex and non-linear motion, being able to easily incorporate changes in acceleration, and providing a more intuitive understanding of the relationship between time and position. They also allow for more accurate predictions and analysis of the particle's motion.
4. How are parametric equations used in real-life applications?
Parametric equations for particle motion have numerous real-life applications, such as in the fields of physics, engineering, and computer graphics. They are used to model the motion of objects in space, predict the trajectory of projectiles, simulate the movement of vehicles, and create realistic animations in video games and films.
5. Can parametric equations be used for three-dimensional motion?
Yes, parametric equations can be extended to describe three-dimensional motion. In this case, there would be three parameters, usually denoted as x, y, and z, to represent the position, velocity, and acceleration of the particle in three-dimensional space. They are commonly used in fields such as aerospace engineering, robotics, and computer graphics to model and simulate complex three-dimensional motion.
