Partial derivative w.r.t. another partial derivative
The discussion focuses on calculating the expression $$\frac{\partial}{\partial x}\left(\frac{\partial L}{\partial(\partial\phi / \partial x)}\right)$$ for the given Lagrangian $$L = \left(\nabla\phi + \dot{\textbf{A}}\right)^2$$. The initial calculations suggest that the result includes a term from the vector potential A, which raises questions about its significance. Participants clarify that the Lagrangian should be interpreted as a dot product, leading to the conclusion that the term involving A may not contribute under certain conditions. Ultimately, the goal is to demonstrate that $$\nabla^2 \phi = 0$$ by summing the derivatives correctly.
cc94
Given
$$L = \left(\nabla\phi + \dot{\textbf{A}}\right)^2 ,$$
how do you calculate $$\frac{\partial}{\partial x}\left(\frac{\partial L}{\partial(\partial\phi / \partial x)}\right)?$$
By summing over the x, y, and z derivatives, the answer is supposed to show that ##\nabla^2 \phi = 0##.
My vector calculus isn't too good, so here's my guess ( ##\partial\phi / \partial x \equiv \phi_x##):
$$\begin{align}
\frac{\partial L}{\partial(\phi_x)} &= 2(\nabla\phi + \dot{\textbf{A}})\cdot\left[\frac{\partial}{\partial\phi_x} (\nabla\phi + \dot{\textbf{A}})\right] \\
&= 2\left(\langle\phi_x + A_x,\phi_y + A_y,\phi_z + A_z\rangle\right)\cdot\left[\frac{\partial}{\partial(\phi_x)}\langle\phi_x + A_x, \phi_y + A_y, \phi_z + A_z\rangle\right] \\
&= 2\left(\langle\phi_x + A_x,\phi_y + A_y,\phi_z + A_z\rangle\right)\cdot\langle 1,0,0\rangle\\
&= 2(\phi_x + \dot{A}_x)
\end{align}
and so
$$\frac{\partial}{\partial x}\frac{\partial L}{\partial(\phi_x)} = 2(\phi_{xx} + \dot{A}_{xx})$$
and summing gives ##\nabla^2\phi + \nabla^2 \dot{A}##.
So did I calculate ##\frac{\partial L}{\partial(\phi_x)}## correctly? If so, why is there still an A term at the end?
This is a meaningless equation. The power operator is not defined for vectors. ##\vec x \vec x = ## ?
If it were written as ##L =|\nabla\phi + \dot{\textbf{A}}|^2##, it would be equivalent to ##L =\left(\nabla\phi + \dot{\textbf{A}}\right) \cdot \left(\nabla\phi + \dot{\textbf{A}}\right)##. Then your result would be correct except for a factor of 2.
Er, yeah the power is supposed to be the dot product like you wrote. Ok, so I just have to figure out why the A term is zero. Thanks!
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
