Python Partial pivoting in getting the reduced row echelon form of a matrix
The discussion focuses on the concepts of row echelon form and reduced row echelon form (rref) of matrices, emphasizing the uniqueness of rref for each matrix. It details the distinction between Gaussian elimination and Gauss-Jordan elimination, outlining that Gaussian elimination consists of a forward pass to achieve row echelon form and a backward pass for back substitution, while Gauss-Jordan elimination directly transforms the matrix into rref. The importance of partial pivoting is highlighted, which is used during the forward pass to mitigate floating-point precision errors, although it is clarified that it does not completely eliminate such errors. The conversation also addresses the confusion surrounding the implementation of these methods in code, particularly regarding whether partial pivoting should be applied during the backward pass. The participants express uncertainty about the definitions and applications of these methods, suggesting a need for further clarification and study on the topic.
psie
TL;DR Summary
I've been trying to write a small code that takes as input an augmented matrix and outputs the reduced row echelon form of the matrix. A classic exercise probably. It's important to me that the algorithm follows Gauss elimination method, and not the Gauss-Jordan method, although these are very similar. I'm not sure the code below is true to the Gaussian elimination method, maybe it isn't? Anyway, I have a question about another thing that's part of the algorithm; partial pivoting.
I assume the reader is familiar with row echelon form of a matrix and reduced row echelon form (rref) of a matrix, the latter which is unique for each matrix. For instance, the augmented matrix $$\begin{pmatrix} 1&0&1&1\\ 1&1&-1&2\\ 2&0&1&0 \\ 0&-1&1&-3\end{pmatrix}$$has rref $$\begin{pmatrix}1&0&0&1\\ 0&1&0&5\\ 0&0&1&2\\ 0&0&0&0\end{pmatrix}.$$By augmented matrix I mean that the last column of the matrix is actually not part of the rest of the matrix (the last column is the constant vector ##b## and the rest of the matrix the so-called coefficient matrix ##A## in the system ##Ax=b##), but everything gets row reduced by the same operation, so hence it's convenient to put it all into one matrix.
For the distinction between Gauss elimination and the Gauss-Jordan method, I have found this website to provide a good overview. In my book for instance, they say that Gauss elimination consists of two parts (where I myself have included the partial pivoting step in part 1):
Part ##1## (forward pass):
  • In the leftmost nonzero column of an ##m\times n## augmented matrix, identify in absolute value the largest row entry and then, if necessary, swap this row with the ##1##st row. This is called partial pivoting and apparently avoids floating-point precision error. The row entry that is largest in absolute value and now lies in the ##1##st row is called a pivot. Make the pivot equal ##1## and then row reduce all entries below the pivot to ##0##.
  • Then consider row ##2## and create a ##1## in the leftmost possible column by partial pivoting, but without using previous row(s). Row reduce the entries below the pivot to ##0##.
  • Continue with the next row and create a ##1## in the leftmost possible column by partial pivoting, but without using previous row(s). Terminate when the column or row of the previous pivot equals ##\min(m,n-1)##.
Part ##2## (backward pass):
  • Starting from bottom to top, find the column of the first nonzero entry in each row (this nonzero entry will be a pivot and equal ##1##). Then row reduce the entries above the pivot to ##0##.
  • Repeat the previous step for each row and stop when you reach the first row.
On the other hand, in Gauss-Jordan elimination one transforms the (augmented) matrix into reduced row echelon form by using the first nonzero entry in each row to make zero all other entries in its column.
That's how my book describes the difference between the two methods. It's not very clear to me what the difference is actually.
Anyway, below follows an implementation of transforming an augmented matrix into rref that I've been working on, using what I think is Gauss-Jordan's method. First, part ##0## and part ##1## of the code below is a modification of some code I found online. I then added part ##2##, i.e. getting the augmented matrix from row echelon form (with normalized pivots, i.e. pivots equal to ##1##) to reduced row echelon form:
[CODE lang="python" title="rref of augmented matrix"]
# reduced row echelon form (rref) with partial pivot (using Gauss-Jordan's method?)
import numpy as np
nearzero = 1.0e-10
# part 0; ask for input
M = int(input("Enter the no. of rows of augmented matrix: "))
N = int(input("Enter the no. of columns of augmented matrix: "))
A = np.zeros((M,N))
print("Enter the rows of the augmented matrix; {} numbers, separated by comma (e.g. 1,2): ".format(N))
for i in range(M):
print("Type in row {}: ".format(i+1))
l=[float(x) for x in input().split(",")]
A = np.array(l)
print("The augmented matrix is: \n", A)
# part 1; forward pass (put the matrix on row echelon form with normalized pivots)
pivotRow = 0
for column in range(N-1):
if pivotRow == min(N-1, M):
break
# partial pivot
bestRow = pivotRow
for row in range(pivotRow + 1, M):
if (abs(A[row, column]) > abs(A[bestRow, column])):
bestRow = row
if bestRow != pivotRow:
A[[pivotRow, bestRow], column:] = A[[bestRow, pivotRow], column:]
# elimination (provided non-zero pivot)
if abs(A[pivotRow, column]) > nearzero:
A[pivotRow, column:] = A[pivotRow, column:] / A[pivotRow, column]
A[row, column:] -= A[row, column] * A[pivotRow, column:]
# avoiding round-off errors
A[row, column] = 0.0
pivotRow += 1
else:
A[pivotRow,column] = 0.0
print("The row echelon form of the augmented matrix is: \n",A)
# part 2; backward pass (put the matrix on reduced row echelon form)
for i in reversed(range(M)):
for j in range(N-1):
if abs(A[i, j]) > nearzero:
for row in reversed(range(i)):
if abs(A[row, j]) > nearzero:
A[row, j:] -= A[row, j] * A[i, j:]
break
print("The rref of the augmented matrix is: \n ", A)
[/CODE]
Here's the output of the code when I input the augmented matrix above.
[CODE title="output"]
Enter the no. of rows of augmented matrix: 4
Enter the no. of columns of augmented matrix: 4
Enter the rows of the augmented matrix; 4 numbers, separated by comma (e.g. 1,2):
Type in row 1:
1,0,1,1
Type in row 2:
1,1,-1,2
Type in row 3:
2,0,1,0
Type in row 4:
0,-1,1,-3
[[ 1. 0. 1. 1.]
[ 1. 1. -1. 2.]
[ 2. 0. 1. 0.]
[ 0. -1. 1. -3.]]
[[ 1. 0. 0.5 0. ]
[ 0. 1. -1.5 2. ]
[ 0. 0. 1. 2. ]
[ 0. 0. 0. 0. ]]
[[ 1. 0. 0. -1.]
[ 0. 1. 0. 5.]
[ 0. 0. 1. 2.]
[ 0. 0. 0. 0.]]
[/CODE]
My question is; in the forward pass, one is swapping rows to partly avoid floating-point precision error. Shouldn't this be done in the backward pass too then? For instance, if you consider the row echelon form of the matrix in the output above, i.e. the third column, we have that ##-1.5## is greater in absolute value than ##1.##. Swapping their rows would not be a good idea though. Maybe I don't fully understand what partial pivoting is all about?
Technology news on Phys.org
Maybe it isn't clear what the distinction between Gaussian elimination and Gauss-Jordan's method is in the literature. And I guess a partial pivoting in the backward pass just makes no sense (maybe there isn't even a backward pass depending on which method you choose to implement).
No, it is Gauss-Jordan but we will come back to this later.
In what you have called the "backward pass", you are trasforming the matrix which is in row echelon form to reduced row ecehlon form. If you swap rows 2 and 3 what will be the value in column 2 of row 3? Will the matrix still be in row echelon form?
That is not a good example to work with because it represents a system of 4 equations in 3 unknowns.
I think that is a confusing statement. Gaussian elimination refers to transformation of a matrix to row echelon form by elementary row operatons. To obtain the solution of a system of linear equations involves a second stage: back-substitution.
Partial pivoting is not a separate step, it is simply a strategy for deciding which row operations to perform.
Partial pivoting does not avoid floating point precision error (which we normally call 'round-off error'), only reduce it. You say 'apparently' - it is essential that you understand how it does this and you should go back and revise this topic, either in your book, the notes I linked here before, or perhaps https://en.wikipedia.org/wiki/Round-off_error
Part 1 is Gaussian elimination (with partial pivoting and normalization).
Part 2 is Gauss-Jordan.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
