Jeremy Wittkopp
- 4
A particle slides on the outer surface of an inverted hemisphere. Using Lagrangian multipliers, determine the reaction force on the particle. Where does the particle leave the hemispherical surface?
L - Lagrangian
qi - Generalized ith coordinate
f(r) - Holonomic constraint
Qi - Generalized force of constraint on the ith particle
λj - Lagrangian multiplier
[tex]\frac{d}{dt}\frac{\partial L}{\partial \dot q_i} - \frac{\partial L}{\partial q_i} = \sum_{j=0}^k \lambda_j \frac{\partial f_j}{\partial q_i},\ i = 1, ..., n \ j = 1,... k\\ \\
x = r * \sin\theta * \cos\phi\\
y = r * \sin\theta * \sin\phi\\
z = r * \cos\theta\\
f(r) = r - R = 0\\
Q_i = \sum_{j=0}^k \lambda_j \frac{\partial f_j}{\partial q_i}[/tex]
So I was able to derive the potential energy [tex]U = mgr \cos\theta[/tex] the kinetic energy [tex]T = \frac{1}{2}m(\dot r^2 + r^2 \dot\theta^2 + r^2 \dot\phi^2 \sin^2\theta)[/tex]I then inserted them into the Lagrangian and got the two equations
[tex]\frac{d}{dt}\frac{\partial L}{\partial \dot q_i} - \frac{\partial L}{\partial q_i} = \lambda_r * \frac{\partial f}{\partial r} \\
\frac{d}{dt}\frac{\partial L}{\partial \dot q_i} - \frac{\partial L}{\partial q_i} = \lambda_\theta * \frac{\partial f}{\partial \theta}[/tex]
Where [tex]\frac{\partial f}{\partial r} = 1[/tex] and [tex]\frac{\partial f}{\partial \theta} = 0[/tex]
But after inputting L into these two equations I get:
[tex]Q_r = m \ddot r - mg\sin\theta - mr \dot \theta^2 - mr \dot \phi^2 \sin^2\theta[/tex]
I think there is something wrong here, but it may just be me. Also, I already searched through other threads to find this answer.
