Particle in a box: Finding <T> of an electron given a wave function
Mayhem
An electron in a carbon nanotube of length ##L## is described by the wavefunction ##\psi(x) = (2/L)^{1/2}\sin{(\pi x/L)}##. Compute the expectation value of the kinetic energy of the electron.
##\left \langle \Omega \right \rangle = \int \psi^* \hat{\Omega}\psi ~d\tau##
If ##\hat{T} = -\frac{\hbar}{2m}\frac{\mathrm{d^2} }{\mathrm{d} x^2}##, then the expectation value of the kinetic energy should be given as:
$$\begin{align*}
\left \langle T \right \rangle &= \int_{0}^{L} \sqrt{\frac{2}{L}} \sin{\left(\frac{\pi x}{L}\right)} \hat{T}\sqrt{\frac{2}{L}}\sin{\left(\frac{\pi x}{L}\right)} dx \\
&= \frac{-\hbar^2}{mL} \int_{0}^{L} \sin{\left(\frac{\pi x}{L}\right)} \frac{\mathrm{d^2} }{\mathrm{d} x^2} \sin{\left(\frac{\pi x}{L}\right)} dx \\
&= \frac{\pi^2 \hbar^2}{mL^3} \int_{0}^{L} \sin^2{\left(\frac{\pi x}{L}\right)} dx \\
&=\frac{h^2}{8mL^2}
\end{align*}
Are my calculations correct?
To solve the integral ##\int \sin^2(f(x))) dx## I use the half angle identity for ##\sin(x)##.
Likes bob012345, vanhees71 and Delta2
Looks good, although generally ##\hbar## is used in QM.
Likes vanhees71 and Mayhem
Wouldn't the ##\hbar## reduce to ##h## in the last step, though?
Likes vanhees71
Yes, but it's not conventional to switch between ##\hbar## and ##h## depending on whether you can cancel ##2\pi##. Most QM texts will stick with ##\hbar## by convention.
Confusing, but who am I to tell quantum physicists that they are wrong.
  • Haha
Likes Twigg, vanhees71 and Delta2
Just reviewed my book: it actually uses ##h## when ##\hbar## reduces as shown. I suppose I'm right in this particular case.
An important point of this problem is to realize that, in this case, the expectation value of the kinetic energy is equal to the energy of the ground state because the particle is in an energy eigenstate and the potential energy is zero. There is no need to integrate.
Modern texts and tracts use ##\hbar## exclusively I am told.
The reason is probably having to be different.
Same applies when all of a sudden ## m_0 ## in relativity is taboo. So we said goodbye to ## E = mc^2 ## for moving particles. It was good enough for Feynman but not for us. :frown:
IMO, it is good to keep in mind that ##\hbar## is used interchangeably with ##h##, but I honestly err on the side of unambiguous notation.
To elaborate, perhaps a bit unnecessarily, on post 7:
Given ## \psi(x) = (2/L)^{1/2} sin(\pi x/L) ## in a box of length L,
The energy eigenstate n (collapsed wave function) of a particle in that box is
## \psi(x)_{E_n} = (2/L)^{1/2}~sin (n\pi x /L) , 0~<=x~<=L ##
and ## \psi(x) = \Sigma_n~ A_n~ \psi_{E_n} (x) ##
with ##A_n = \int_0^L ~\psi^*_{E_n} (x) ~ \psi(x) ~dx ##
= 1, n=1 and = 0 for any other n
so there is only one allowed energy state with ## E = \hbar^2 \pi^2/2mL^2 ##
(from the eigenstate Schroedinger equation).
