Particle in a box Schrodinger equation
In summary, the particle in a box problem involves a time-independent potential, which is why the time-independent Schrodinger equation is used. This equation allows for separation of variables and leads to eigenstates of the Hamiltonian operator. In the specific case of the particle in a box, the potential energy is zero inside the box and infinite outside, in order to confine the particle to a finite volume.
gkiverm
I'm going though the particle in a box lesson in my physics textbook right now. I understand all the math, but don't understand a lot of the physics behind it. Also this is an intro physics course, we're only covering the basics of quantum mechanics and not going into too much detail.
How come we use the time independent Schrodinger equation for the particle in a box problem? In general, do you always use the time independent Schrodinger equation for stationary state (energy is known with no uncertainty)?
Why is the potential energy of the particle inside the box always equal to zero and infinite outside the box?
Thanks
The problem involves a time-independent potential which is why we resort to the time-independent Schrodinger equation. When you have a time-independent potential you can use separation of variables to write the coordinate representation of the state vector (i.e. the position wave-function) as ##\Psi(\mathbf{x},t) = \psi(\mathbf{x})\varphi(t)##. Plugging this into the time-dependent Schrodinger equation it is easy to show that ##\varphi = e^{-iEt/\hbar}## and ##\frac{-\hbar^2}{2m}\nabla^2 \psi + V\psi = E\psi## where ##E## is the separation constant; the latter of these is the time-independent Schrodinger equation.
The solutions ##\psi## are eigenstates of the Hamiltonian operator that you see on the left hand side of the equation of motion for ##\psi##; we identify ##E## as the total energy since this is the observable associated with the Hamiltonian operator.
For the particle in a box problem we have ##V = 0## inside the box and ##V = \infty## at the walls of the box because that's how the system is setup. We want the particle to be confined to a finite volume in space but be free within this finite volume so we have zero potential inside (hence it is free inside) while placing an infinite potential barrier in the form of a box to keep the particle confined inside.
Related to Particle in a box Schrodinger equation
1. What is the "Particle in a box Schrodinger equation"?
The "Particle in a box Schrodinger equation" is a mathematical equation that describes the behavior of a particle confined to a one-dimensional box. It is a simplified version of the Schrodinger equation, which is a fundamental equation in quantum mechanics.
2. What does the "box" in the "Particle in a box Schrodinger equation" refer to?
The "box" in the "Particle in a box Schrodinger equation" refers to the boundaries or constraints that confine the particle to a specific region in space. This can be a physical box or any other type of confinement.
3. How is the "Particle in a box Schrodinger equation" solved?
The "Particle in a box Schrodinger equation" is solved by using mathematical techniques, such as separation of variables and boundary conditions, to find the possible energy levels and wavefunctions of the particle within the box.
4. What are the implications of the "Particle in a box Schrodinger equation" in quantum mechanics?
The "Particle in a box Schrodinger equation" is an important model in quantum mechanics as it helps to understand the behavior of particles in confined spaces. It also provides insights into the quantization of energy levels and the wave-particle duality of quantum particles.
5. Is the "Particle in a box Schrodinger equation" applicable to real-world systems?
The "Particle in a box Schrodinger equation" is a simplified model and may not accurately describe all real-world systems. However, it can be used to understand and predict the behavior of particles in confined spaces, such as electrons in a semiconductor device.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
9K
