MHB Particles rotating about each other with uniform angular speed
Two particles of mass m and M rotate around a common center of gravity under an attractive force F, maintaining a separation R and an angular velocity ω. The correct equations for the forces acting on each mass are F = mω²r₁ and F = Mω²r₂, where r₁ and r₂ are the distances from each mass to the center of rotation. The total separation R is the sum of these distances, R = r₁ + r₂. The relationship between R, F, and ω is established as R = (F/ω²)(1/m + 1/M). The discussion emphasizes the necessity of equal angular velocities for the system to maintain a constant separation.
Fantini
MHB
Here's the problem:
Two particles of mass $m$ and $M$ undergo uniform circular motion about each other at a separation $R$ under the influence of an attractive force $F$. The angular velocity is $\omega$ radians per second. Show that
$$R = \frac{F}{\omega^2} \left( \frac{1}{m} + \frac{1}{M} \right).$$
I don't understand what is meant by undergo circular motion about each other.
Mathematics news on Phys.org
Fantini said:
Here's the problem:
Hi Fantini,
For instance 2 bodies attracted by gravity do that.
In that case they both make a circular movement around the common center of gravity.
Thank you, ILS. This confirms my initial sketch of the situation was correct. A colleague managed to solve it during a brainstorm today. Here's the solution.
For each body we can equate the resultant force to mass times the acceleration it feels, therefore we have the set of equations
$$F = \frac{m \omega^2 R}{2}, \text{ and } F = \frac{M \omega^2 R}{2}.$$
Isolating $R$ in both gives
$$R = \frac{2F}{m \omega^2} \text{ and } R = \frac{2F}{M \omega^2}.$$
Adding them results in
$$2R = \frac{2F}{\omega^2} \left( \frac{1}{m} + \frac{1}{M} \right)$$
and we have
I believe... that is not correct.
It seems your colleague is assuming that the common point of rotation is halfway the 2 masses, but as I see it, there is nothing that suggests that.
It appears to be accidental that the right answer came out.
As I see it, mass $m$ has a distance of $r_1$ to the common point of rotation.
And mass $M$ has a distance of $r_2$ to the common point of rotation.
I believe that the proper set of equations is:
\begin{cases}
F=m\omega^2 r_1 \\
F=M\omega^2 r_2 \\
R=r_1+r_2
\end{cases}
I see. So if mass $m$ is closer to the center of rotation than mass $M$ then it should have a smaller speed because it covers less distance, while mass $M$ has greater speed because it covers greater distance.
Either way, they are always at an angle of $\pi$ with each other such that $R$ is constant, correct?
Either way, they are always at an angle of $pi$ with each other such that $R$ is constant, correct?
Exactly.
The force $F$ is the centripetal force that dictates the relation between the $\omega$'s and the respective radiuses.
The separation $R$ can only be constant if the $\omega$'s are the same, meaning the angle is a constant $\pi$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
