Particle's Velocity in t: -kt^3 + c
  • Thread starter Thread starter Cbray
    Velocity
The particle's acceleration is inversely proportional to time cubed, described by the equation a = -kt^3. The velocity at t=1 is given as 3 m/s, and it approaches a limiting value of 5 m/s as time increases. By integrating the acceleration, the velocity can be expressed as v = -k/2t^2 + d. Using the known values, when t approaches infinity, d equals 5, leading to the equation v = -k/2t^2 + 5. Finally, substituting t=1 into the equation allows for the calculation of the constant k.
Cbray
A particle moves in a straight line with acceleration which is inversely proportional to t3 , where t is the time. The particle has a velocity of 3ms-1 when t=1 and its velocity approaches a limiting value of 5ms-1 . Find an expression for its velocity at time t.
a=-kt^3
*****ROOKIE MISTAKE SHOULD BE -2/t^2 + d (last equation)***
I won't answer the question directly for you, but this is just a basic algebra problem, remember that when y is proportional to x, you use the formula y=kx where k is some constant, inversly proportional to x and you have y = k/x. Once you know how y is proportional to x, and you have test values for y and x, you can plug them in and solve for k.
I did some more and got stuck again, do you mind looking at it?
I'm not entirely sure what you did there here's what would be a good idea:
∫ dv/dt dt = k∫1/t^2 dt
v= -k/2t^2 + d
now you know that when t=1 v=3, and you also know that the limiting velocity (when t→∞) is 5, so when t→∞, d=v, and v= 5, so d = 5, so now you have the formula
v=-k/2t^2 + 5, and you know that when t=1, v=3.
so just plug it in and solve for k
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
