Fortran Passing variables in FORTRAN
  • Thread starter Thread starter Milleniumeye
    Fortran
To pass variable values between FORTRAN programs, the recommended approach is to use subroutines or functions rather than attempting to share variables directly between separate programs. The main program can call subroutines, passing parameters for calculations. If the programs must run sequentially, one option is to write the variables to a file in either binary or formatted character data, allowing the second program to read them. This method preserves data integrity better with binary formats, while formatted data is easier to read but may lead to rounding errors.Using common blocks to share variables is also possible but comes with risks, such as hidden bugs from variable name mismatches and datatype inconsistencies. While common blocks can improve performance, they require careful management to avoid complications. Overall, using subroutines for parameter passing or file I/O for data transfer is more reliable and manageable in FORTRAN programming.
Milleniumeye
TL;DR
It is necessary to pass the value of a variable from one FORTRAN program to another.
I need to pass the value of a variable from one FORTRAN program to another. The main program carries out calculations with some numerical inputs a,b , I want to enter numerical values of variables in another program like
real*8 a, b
common/variables/a,b
a = 1.
b = 2.
How should I declare them in the main program and how should I compile the file? This option resulted in an error:
error: unknown type name 'real'
Technology news on Phys.org
That's a C compiler error. How are you compiling your FORTRAN?
Also, one program runs at a time - there is no way to pass variables between programs. Are you sure you don't mean subroutines or functions?
Have the first program write the variables to a file and the second program read the file.
Likes jedishrfu and FactChecker
Or write a top level script that parses outputs from one program and calls another with data on the command line.
To extend this answer, you can either write the variable values in binary or as formatted character data. The binary approach preserves the value of the data better than the formatted character approach which may round the data depending on the precision you use.
One could also write the data in a user defined environment variable to be read by the second program. It would have to be formatted character data.
This approach is good for a small number of variables vs a file approach which can handle large amounts of data.
In FORTRAN, list directed writes and reads are a convenient way to pass data in a formatted file that can be easily read by a programmer or another FORTRAN program. That can really help in debugging. (See List-Directed I/O)
Why are you trying to use "common" variables instead of the usual argument-passing mechanism for subprograms or functions?
Likes Vanadium 50
Milleniumeye said:
TL;DR Summary: It is necessary to pass the value of a variable from one FORTRAN program to another.
Your question isn't very clear. My thought is that you aren't used to the terminology used in Fortran programming. What I believe you are asking about is how to pass values from a Fortran main program to a subroutine or function. Each Fortran "program" will have a block of code like the following:
Fortran:
program CalcArea
<declarations>
<code>
end program CalcArea
Most Fortran programs other than the most trivial additionally include subroutines and/or functions that are called from the main program. The main program will often communicate with the subroutines or functions by passing parameters. This seems to me what you are asking about.
If that's the case, here's some example code in which the main program calls three separate subroutines -- one to get input from the user, another to do some calculations, and a third to output the results. The example, which I found here, https://web.chem.ox.ac.uk/fortran/subprograms.html, is a bit archaic in its style with everything in all caps, but it should give you an idea of what parameter passing looks like.
Fortran:
PROGRAM SUBDEM
REAL A,B,C,SUM,SUMSQ
CALL INPUT( A,B,C)
CALL CALC(A,B,C,SUM,SUMSQ)
CALL OUTPUT(SUM,SUMSQ)
END
SUBROUTINE INPUT(X, Y, Z)
REAL X,Y,Z
PRINT *,'ENTER THREE NUMBERS => '
READ *,X,Y,Z
RETURN
END
SUBROUTINE CALC(A,B,C, SUM,SUMSQ)
SUM = A + B + C
SUMSQ = SUM **2
RETURN
END
SUBROUTINE OUTPUT(SUM,SUMSQ)
REAL SUM, SUMSQ
PRINT *,'The sum of the numbers you entered are: ',SUM
PRINT *,'And the square of the sum is:',SUMSQ
RETURN
END
I seem to remember using the COMMON command. That sets aside common memory which each subroutine or function writes and reads. IIRC, it's a blank, unformatted area of memory and the variables need to be defined carefully so the routines all know which location is which.
Is the OP still here? @Milleniumeye , can you comment on the suggestions you've received?
Likes Vanadium 50
Yes to @sophiecentaur.
The common block was a way to share variables across the program space. It's akin to a global struct used in C programming.
pros:
- improved program speed since they weren't needed in the subroutine call.
- common block names had to be the same wherever used
- common block variable names could vary as could their datatype but the programmer needed to know what they were doing (changing datatype was considered a very bad coding practice)
cons:
- common variable names could be different or datatype could be different which led to hidden bugs
Some of the errors I saw:
- large common block programmer forgot to list a variable shifting the variables over one place
- similarly someone adding a new variable and forgetting to change all common blocks
- one or more variable name were changed and implicit or explicit datatype rules changed them from integer to real or vice versa
I saw these used in old Fortran programs used for turbine modeling.
Likes sophiecentaur
jedishrfu said:
pros:
...programmer needed to know what they were doing
Some would call this a "con".
In some ways, it was more like a union than a struct. As such, when things went wrong, they went spectacularly wrong.
Like many features in many languages, common blocks got a bad rep from overuse and people coding before thinking. "Hey, let's just put everything into one giant common block!" is not a good idea.
Likes sophiecentaur and jedishrfu
But the common block was a feature for the times. Subroutine calls in FORTRAN were not recursive. Subrourine calls did not pass by value. Arguments often used one of several CPU registers for their address.
Using common blocks allowed for faster processing as indexing was somewhat slower.
It was a dangerous time for programming. In one of my programs, I recall passing a numerical constant, 3 ( a 2=pendown and a 3=penup ) to third party subroutine. The subroutine had an obscure side-effect and changed the argument value to a 2 and I got the craziest looking plots. Basically everywhere I used a 3 now became a 2.
It was issues like this that drove language design to be more protective of data constants.
Likes sophiecentaur and FactChecker
It depended on the compiler and the care taken by the programmer. Using VAX Fortran-77, one could do recursion and reentrance quite well as long as one took care to keep ones paws off locally declared variables.
I would usually allocate a hunk of dynamic memory and pass its address in as a parameter. The subroutine could treat that parameter as a structure or as an array. There was no language-provided guarantee that this would work as expected, but it did work quite reliably and well.
There was a language issue that a subroutine could not directly call itself. Within the subroutine, the subroutine name is used to denote the function return value. It can be used on the left hand side of an assignment statement, not on the right hand side of a call or in a function invocation. So you would cheat and call a jacket subroutine which could then call you back.
I would often use the AST (Asynchronous System Trap) control block (ACB) as the dynamically allocated storage area. This made integration with system services quite convenient and acceptably re-entrant.
On VAX or Alpha, language extensions %val, %ref, %descr and %loc could be used to populate the argument list in the proper way to make this work smoothly.
It has been decades since I did this for a living.
I avoided common blocks. Real quiche-eaters can write Pascal in any language.
Datatrieve on VAX was a reporting language that allowed function invocations but not assignment statements or conditional code execution. This made it impossible to take context-specific actions. But if one invoked a function with purpose-built side effects, much became possible!
My FORTRAN experience was first with Fortran-IV and later with Honeywell Fortran-Y which was IV with some added features like the CHARACTER datatype and freeform coding. (no more punch card limitations ie code col 7 thru 72 with line nos in cols 1-5, continuation indicator col 6 and sequence nos in cols 73-80).
Freeform had some gotchas:
- a C in column 1 made the line a comment
- woe to the programmer who wrote CALL, CHARACTER, COMPLEX or COMMON ... starting in column 1 many compile time errors would result
In this dialect of FORTRAN:
- calls to subroutines were all call by reference (if you passed a constant its value could be changed)
- recursion was not a feature (recursive factorial would result in an endless loop)
- no stack
- constants were stored with variables and were mutable
I suppose the OP isn't coming back, so we can all reminisce about the Good Old Days.
Computed GOTO anyone? Talk about job security!
Likes hutchphd and Astronuc
My first exposure was pre-Fortran I. Since there is no Roman numeral for zero, it was just called Fortran. We didn't have those new-fangled Hollerith cards -- we had to chisel our code into clay tablets that were then baked for XII hours. The tablet readers read the tablets and then glued wires to specific junctions in the computing machine (which was powered by oxen chained to arms radiating from a spindle). Talk about turn-around times! If your code had no bugs (literal insects that got baked into the tablets), you might get results back by the next full moon.
  • Haha
Likes FactChecker and berkeman
Clay? You had clay? You were lucky!
And oxen? Pure luxury! :smile:
  • Haha
Likes FactChecker
And when the Internet came along, you uploaded the tablets to the cloud via pack trains of llamas. Or were they alpacas?
  • Haha
Likes hutchphd and Mark44
Shades of the Four Yorkshiremen...
  • Haha
Likes sophiecentaur
The FORTRAN Yorkshiremen.
  • Haha
Likes jtbell and Mark44
Wearing frocks?
sophiecentaur said:
Wearing frocks?
Wrong Monty Python skit. The Four Yorkshiremen were at their club, smoking cigars and drinking Château de Chasselas, comparing notes about how things were when they were young. If you haven't seen it, search for "Four Yorkshiremen" on Youtube.
Try again. ‘Trans’ = frocks.
Shouldn't that be the FORTRAN IV Yorkshiremen?
  • Haha
Likes Vanadium 50
  • · Replies 59 ·
11K
  • · Replies 19 ·
