Engineering Passive Sign Convention in circuit
The discussion centers on calculating power in a circuit with a voltage source and a resistor using the passive sign convention. It is established that when current enters the voltage source through its negative terminal, the source generates power, while the resistor dissipates power. The calculations indicate that both the voltage source and the resistor can have a power value of 10W, with the voltage source acting as a generator. The importance of current direction and voltage polarity in determining power signs is emphasized, noting that independent voltage sources can sometimes dissipate power in complex circuits. Understanding these principles is crucial for accurate circuit analysis.
Air
Calculate the power in the voltage source for this given circuit:
P = \frac{V^2}{R} Or P = - \frac{V^2}{R}
If we take the bottom left corner as the Initial node then and go around the circuit, then the voltage is a drop thus I thought we use: P = \frac{V^2}{R} = 10W however this means power is positive hence the voltage source is also an absorber which wouldn't make sense because there would be no generator in the circuit.
Think about what the voltage source's polarity implies about the direction of the current.
Also, P = VI and Pabsorbed = Pgenerated
The passive sign convention means that when current is entering the element through the negative end of the Voltage then the element is generating power and otherwise it is dissipating power.
So in your problem the independent Voltage source is generating power (as shown in the figure I have uploaded) and the resister is dissipating that power.
So for Voltage source
P (generated) = \frac{V^2}{R} =10W
and for Resistor
P(absorbed) = \frac{V^2}{R} =10W
I hope your problem is solved.
and for Resistor
It isn't given so how did you decide current is going from negative to positive in the voltage source? Also, should P=-10W as the voltage source is a generator?
Power is voltage times current, no matter what your reference node is. If voltage and current have the same sign, power is positive, else it is negative. Positive power means dissipated power and th is always the case in a passive resistor. Negative power is power delivered to the rest of the circuit. This can only happen with an active element, such as a power source.
I would like to add to what CEL has just posted that an Independent Voltage source always maintains the same voltage (In this case 10V) across its terminals with the same polarity. So this is how we get the signs of voltage across the Resistor (10 ohms).
The thing that we do now is to use the knowledge that a resistor is a passive element (always) so current must enter it through the +ve terminal of the voltage.
We also know that acording to KCL all the current through the resistor 'I' also passes through the Voltage Source (entering it from -ve side). Thus it is generating power.
Ho
NOTE: It is not necessary that an Independent source is always generating Power. In complicated circuits an independent source may even dissipate power. In that case you must analyze the circuit using different circuit analysis techniques. I will try to upload a circuit with a power dissipating Independent source here.
This is a circuit in which the Independent Voltage source and the resister are dissipating power while the Independent current source is generating Power.
