Pauli exclusion principle question (again)
In summary, the exclusion principle is a required anti-symmetry in the wavefunction of electrons. It is derived from the wave-function for a two electron system and helps explain chemical stability. If you cannot distinguish between particle symmetry vs. antisymmetry that isn't also confounded with fermions all having repulsion interactions in terms of other forces, an experiment would need to be built to distinguish between the two.
MadRocketSci2
48
I've seen it stated in many places that the reason why atoms don't collapse is due to the pauli exclusion principle. The exclusion principle is given as a required anti-symmetry in the wavefunction of electrons.
I don't understand how this principle was derived, or where it comes from. (I've seen the derivaiton in Bates, but all that proves is that wavefunctions that start either symmetric or asymmetric, that have a Hamiltonian that is symmetric with respect to particles (particles behave the same) will remain symmetric or antisymmetric.)
It seems to me that the electrostatic repulsion of electrons suffices to explain the electronic structure of an atom. If you have a joint wave-function for 2 electrons, the electrostatic repulsion potential would enforce Phi(x,x) = 0 for states where x1=x2. If you had "boson electrons" where Phi(x2,x1) = +Phi(x1,x2), but Phi(x1,x1) = 0 due to the electrostatic repulsion, how you could distinguish between the behavior of an atom with "boson electrons" and one with "fermion electrons"? The conjugate product of the wavefunction with itself should come out the same in both cases.
If you cannot distingish between these cases, then why is antisymmetry necessary to explain electronic structure, and not simply some sort of repulsion potential that blows up at 0 distance? (The repulsion potential ensures that the ground state wavefunction cannot be separable, and isn't equivalent to the independent ground state wavefunctions of single electrons in the same potential)
What experiment could you build that could distinguish between particle symmetry vs. antisymmetry that isn't also confounded with fermions all having repulsion interactions in terms of other forces?
I don't know about Pauli's line of thought, but the wave function for a two electron system, gives a finite probability for them being in the same place.
Why do you believe this to be true?
This can help too.
wikipedia said:
In the early 20th century it became evident that atoms and molecules with even numbers of electrons are more chemically stable than those with odd numbers of electrons. In the famous 1916 article "The Atom and the Molecule" by Gilbert N. Lewis, for example, the third of his six postulates of chemical behavior states that the atom tends to hold an even number of electrons in the shell and especially to hold eight electrons which are normally arranged symmetrically at the eight corners of a cube (see: cubical atom). In 1919 chemist Irving Langmuir suggested that the periodic table could be explained if the electrons in an atom were connected or clustered in some manner. Groups of electrons were thought to occupy a set of electron shells around the nucleus.[1] In 1922, Niels Bohr updated his model of the atom by assuming that certain numbers of electrons (for example 2, 8 and 18) corresponded to stable "closed shells".
Pauli looked for an explanation for these numbers, which were at first only empirical. At the same time he was trying to explain experimental results of the Zeeman effect in atomic spectroscopy and in ferromagnetism. He found an essential clue in a 1924 paper by Edmund C. Stoner which pointed out that for a given value of the principal quantum number (n), the number of energy levels of a single electron in the alkali metal spectra in an external magnetic field, where all degenerate energy levels are separated, is equal to the number of electrons in the closed shell of the noble gases for the same value of n. This led Pauli to realize that the complicated numbers of electrons in closed shells can be reduced to the simple rule of one electron per state, if the electron states are defined using four quantum numbers. For this purpose he introduced a new two-valued quantum number, identified by Samuel Goudsmit and George Uhlenbeck as electron spin.
<quote>Why do you believe this to be true? </quote>
For states of finite energy, Phi doesn't (and cant) diverge from zero wherever the hamiltonian blows up. I'll need to confirm this later (when I have more time), but it has been true in my investigations so far.
Pauli exclusion follows from the spin-statistics theorem of quantum field theory.
An example: if electrons were bosons atomic orbitals would fill up differently. "Bosonic electrons" would all try to crowd into the lowest energy level of the atom instead of being forced into higher orbitals as the lower ones filled up. (They wouldn't entirely succeed, because of the electrostatic repulsion between electrons, but they would do a lot better than fermionic electrons).
The antisymmetry requirement ##\phi(x_1, x_2) = -\phi(x_2, x_1)## is *much* stronger than the requirement ##\phi(x_1, x_2) = 0##. It's common to quote the Pauli exclusion principle as saying "no two electrons (with the same spin) can be in the same place at the same time," but this is a simplification intended for people who don't know about wave functions. The actual rule is the much stronger antisymmetry restriction.
As Avodyne says, the fact that spin-1/2 particles like electrons have to be fermions can be proven in quantum field theory, but has to be taken on faith before you learn QFT.
The Hamiltonian does not blow up. The Coulomb singularity can be (and in practice is) compensated by a singularity in the kinetic energy operator. Or, re-formulated: There is a finite, non-zero chance that electrons of opposite spin sit right on top of each other, and they can do so just fine as long as the derivatives of the wave function are singular at the coalesence points. Search for Kato cusp conditions if you are interested in this topic.
In the weak correlation limit (e.g., for core electrons), the positions of opposite spin electrons even become completely uncorrelated. That means, the chance of finding two opposite spin core electrons right on top of each other is not significantly lower than finding them anywhere else in individually equivalent positions.
Likes 1 person
Thank you. I was wondering why "two electrons on top of each other" was permissible in any case
(and was trying to pursue some wild goose chase where a magnetic force singularity canceled the coulomb force singularity for opposite spins. I suppose this isn't necessary then.)
Related to Pauli exclusion principle question (again)
1. What is the Pauli exclusion principle?
The Pauli exclusion principle is a fundamental principle in quantum mechanics that states that no two identical fermions can occupy the same quantum state simultaneously. This means that two fermions, such as electrons, cannot have the same set of quantum numbers, including the same spin.
2. Why is the Pauli exclusion principle important?
The Pauli exclusion principle is important because it helps to explain the behavior of particles at a quantum level. It also allows for the stability of matter, as it prevents electrons from all occupying the same energy level and allows for the formation of chemical bonds between atoms.
3. How does the Pauli exclusion principle relate to the electron configuration of atoms?
The Pauli exclusion principle plays a significant role in determining the electron configuration of atoms. It states that each orbital can hold a maximum of two electrons with opposite spins. This means that the electron configuration of an atom is determined by the number of electrons and their distribution in the available energy levels.
4. Can the Pauli exclusion principle be violated?
No, the Pauli exclusion principle is a fundamental law of quantum mechanics and has been extensively tested and proven to be true. Violating this principle would result in a violation of the laws of physics.
5. Who discovered the Pauli exclusion principle?
The Pauli exclusion principle was first proposed by the Austrian physicist Wolfgang Pauli in 1925. It was based on his observations of the behavior of electrons and their spin in the presence of a magnetic field.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
