Peak Electron Number Density of a Beam
The discussion focuses on deriving an expression for the peak electron number density (N0) in a parallel beam of non-relativistic electrons injected into a vacuum. Participants analyze the charge density profile given by ρ = ρ0 cos(πr²/2a²) and express concerns about its validity beyond the beam radius (r < a). They suggest that the current remains constant before and after acceleration, implying that integrating the charge density over the beam profile could relate it to the current and electron velocity. The conversation emphasizes the need to ensure the charge density does not yield negative values outside the beam's defined radius. Ultimately, participants agree to proceed with the assumption that the expression is valid only for r < a.
mickyfitz13
Consider what happens as a parallel beam of non-relativistic electrons with beam radius a is injected as a current I into a region of vacuum after acceleration through a voltage difference V. If the radial profile of the beam can be described as
p=p0 cos(\frac{\pi r^2}{2a^2})​
where ρ is the charge density, find an expression for ρ0 in terms of parameters a, V and I and hence determine the peak electron number density N0 in the beam.
∇.E=p/ε0
∫ ∇.E dV = ∫ E dS
V=∫E dl
p=dQ/dV
My attempt was first substituting in the charge density into Gauss's equation to give
∇.E=p00 cos(\frac{\pi r^2}{2a^2})
Then substituting this into the second equation gives
∫ p00 cos(\frac{\pi r^2}{2a^2}) dV = ∫ E dS
Using p=dQ/dV i got rid of the dV to give;
Q00 cos(\frac{\pi r^2}{2a^2}) = ∫ E dS
and since this is a radial beam then dS=4\pir2 which gives;
E=Q0/4\pir2ε0 cos(\frac{\pi r^2}{2a^2})
Using the potential equation V=∫E dl we can find the potential, however i haven't got that far to calculate due to the fact it feels like I'm going in the wrong direction. What do you's think?
Does anyone have any advice to point me in the right direction?
The charge density looks strange. That cos() expression does not vanish for large r, so you magically convert a well-defined beam into something that spreads out in the whole volume, with positive and negative densities?
Should we assume that this expression is valid for r<a only?
In that case: Current is the same before and after acceleration. If you integrate your density over the beam profile, this number is related to current via the velocity of the electrons. Current/Charge conservation could be enough to solve the problem.
I think it would safe assume that it is for r<a. I think you're right with the theory, i'll try it out anyways and see how it goes from there, thanks!
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
