Pebble accelerated by the wind with a starting velocity
  • Thread starter Thread starter Ursa
    Velocity Wind
The discussion focuses on calculating the velocity and angle of a pebble accelerated by wind using differential equations and the quadratic formula. The initial displacement equation was identified as incorrect due to the factor of 6.0. The calculations for horizontal and vertical velocities yielded results of 11.6 m/s and 7.7 m/s, respectively, leading to a resultant velocity of 13.9 m/s. The angle of projection was determined to be 33.4 degrees using vector components. The conversation emphasizes the importance of using standard kinematics equations for accurate results.
Ursa
A moderate wind accelerates a pebble over a horizontal xy plane with a constant acceleration ##\vec a = (6.0i + 7.0j)m/s^2##. At time t = 0, the velocity is ##(5.0i)m/s## . What are the (a) magnitude and (b) angle of its velocity when it has been displaced by 13.0 m parallel to the x axis?
$$x = \frac {-b \pm \sqrt{b^2 -4ac}} {2a}$$
$$V=\sqrt {V_x^2 + V_y^2} $$
$$a_x=a \cos\Theta$$
I first used differentials to find an equation for the displacement.
$$6.0t^2+5.0t=13$$
and using the quadratic formula I got time ##t=1.1##
I then got ##V_x## from ##6.0t+5.0=v_x=11.6##
and ##V_y## from ##7.0t=v_y=7.7##
The I got v from ##V=\sqrt {V_x^2 + Vy^2} ##
$$\sqrt {11.6^2 + 7.7^2} =13.9 m/s$$
Which I took as my velocity.
from there I used the vector vector competent equation ##a_x=a \cos\Theta## to find the angle
##\cos^{-1}\frac {11.6} {13.9}=\Theta=33.4##
$$6.0t^2+5.0t=13$$
The factor of 6.0 in the first term is not correct. Check the standard kinematics equations for displacement with constant acceleration. Otherwise, your method of solution looks good.
There is no need to find the time.
There are five standard SUVAT equations, each involving four of time, displacement, acceleration, initial velocity, final velocity.
Which three of those are you given, and which are you trying to find? Which SUVAT equation uses just those four?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
