Pelton Wheel for Power Generation
A Pelton wheel can effectively generate power at 45 psi, which falls within the optimal operating range of 15-1,800 meters head. To determine wattage and amperage for 12, 24, or 48 volts, both water pressure and flow rate must be considered, as they directly impact power output. Sufficient water flow is essential, and using two half-inch nozzles may help optimize performance. Care should be taken not to draw too much power, as this could reduce water pressure for downstream users, potentially leading to complaints. Overall, while the concept of harnessing water power is appealing, it requires careful planning and consideration of local water supply dynamics.
Alfredo
I am a simple Newbie, wanting to make power, using Pelton wheel say 45 psi water pressure , 3/8 to 1/2 nozzle...is there a way to determine the results or is there a better psi/nozzle combo? Generator can be 12/24/48 volts
:welcome:
This article https://en.wikipedia.org/wiki/Pelton_wheel#Design_rules shows you how to calculate the performance.
The same article says:
Pelton wheels operate best with heads from 15–1,800 metres (50–5,910 ft), although there is no theoretical limit.
45 psi is within that range.
Keep us posted on your progress.
SO if anyone knows is there a way to determine the wattage and amperage produce-able, for 12...24...48 volts, having 45 psi. I am a novice at formulas.
You will need to have enough flow available at that pressure and orifice size to feed it - what is your source of water?
I have a well that feeds a small neighborhood as it passes my property it has 45 psi per gauge, i was going to implant an encapsulated pelton unit(size to be determined) ,as everyone fills their tanks, constantly.One inch and a quarter line. So two orifices at half inch?
And what maximum rate of flow do you get? As has been pointed out already, Power out will depend on water pressure and flow rate. If you try to take too much power from this water feed, people downstream of you will suffer a reduction in water pressure / flow. This may or may not be relevant. but if they become aware of this and if they know you have 'done something' to their supply, they may complain. Their tanks may take longer to fill if the exit pressure from your generator is significantly lower than at present.
Your power source cannot be totally 'free'. But I can see how tempting the idea is. :smile:
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
