PEM electrolyzer - How does platinum reduce activation energy?
The discussion centers on understanding how platinum affects the activation energy needed to dissociate water (H2O) in PEM electrolyzers. The original poster is seeking clarity on applying the Arrhenius equation to quantify this effect, providing specific operating specifications for a PEM electrolyzer, including input voltage, current, and hydrogen and oxygen production rates. They also reference a previous post regarding volumetric flow rates and the mass of water involved in the electrolysis process. A key point of contention arises around the role of platinum; while one comment asserts that platinum does not reduce activation energy and is primarily used for its oxidation resistance, another counters that platinum black has catalytic properties that lower activation energy, enabling more efficient electrolysis with reduced overpotential. The discussion highlights the complexity of platinum's role in electrolysis and the need for a deeper mathematical understanding of these processes.
HelloCthulhu
I've been researching pem electrolyzers, but still don't understand how to mathematically express how platinum reduces the activation energy necessary to dissociate H2O. I've seen the Arrhenius equation solved before, but didn't understand how to get the values for it. Here are the operating specs for the electrolyzer:
https://www.fuelcellstore.com/manuals/horizon-mini-pem-electrolyzer-instructions-fcsu-010.pdf
- Input Voltage: 1.8V ~ 3V (D. C.)
- Input Current: 0.7A
- Hydrogen production rate: 7ml per minute at 1A
- Oxygen production rate: 3.5ml per minute at 1A
In a previous post, I tried to figure out what the volumetric flowrate would be. Not sure if the mass is necessary to find the activation energy, but I'll include it anyway:
https://www.physicsforums.com/threads/amount-of-water-electrolyzed-during-pem-electrolysis.992823/
2H2O —> 2H2 + O2
3.5 ml O2/min = 0.00015625 M O2(STP)
0.0003125 H2O(l) →0.0003125 H2(g)/1A*min + 0.00015625O2(g)/1A*min
0.0003125M H2O *18 g = 0.005625 g/1A*min H2O
Any help is greatly appreciated!
Chemistry news on Phys.org
Platinum does not reduce activation energy it is only used for electrodes because it resists oxidation better then other materials.
It is not that simple - platinum black has some catalytic properties which make it perfect for electrode material, as when used most processes work with lower overpotential. And - as it is a case with catalysis - it works by lowering activation energy.
Likes HelloCthulhu and Astronuc
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
