- #36
RUTA
- 491
twofish-quant said:That just doesn't make any sense to me. The supernova data is just one piece of the puzzle and has to be understood in the context of other data. In order to do anything with the supernova data, you have to make hundreds of assumptions, and there is no way that you can justify those assumptions without reference to other data. If you had only the supernova data, then you could come up with a lot of alternative explanations.
Thank you for conceding my point.
twofish-quant said:It turns out that none of those observations work in light of other data. If Perlmutter had published and then a year later it turns out that supernova Ia were not standard candles and there is large scale evolution of SN Ia or if it turned out that dark flows were much stronger than expected, it would have been a "merely interesting" paper but not worth a Nobel.
Now as it happens subsequent experiments have tightened error bars, and WMAP shows consistent CMB evidence.
Also note that Perlmutter went in with a hundred assumptions. He was trying to measure the deceleration parameter, which was expected to be positive.
As long as you confine yourself to unmodified GR, I would agree that the alternative explanations do not suffice in light of WMAP.
twofish-quant said:I'm an astrophysicist, not a mathematician. I don't deal with proof. I can't "prove" that the universe is accelerating any more than I can "prove" that the Earth is round.
No single scientific observation is "proof" of anything. You have to view observations as fitting within a model, and right now the idea that universe is accelerating is the best model that people have come up with, and the fact that people have tried really hard and failed to come up with alternative models should tell us something.
I can't *prove* that there isn't a simple explanation that explains everything. I can show that people have tried and failed to come up with an alternative explanations, and the most obvious model right now is pretty darn interesting.
I can't "prove" something is true. I can "prove" something is false, and Perlmutter kills CDM with Lambda=0, which was the standard cosmological model in 1995. The simplest theoretical patch is to assume that Lambda > 0.
Well said.
twofish-quant said:Very strongly disagree. If Perlmutter et al. just got distance moduli for large redshift supernovae and got what people expected, that wouldn't be worth a Nobel. They got the Nobel because they did the observations and got results that *no one* expected.
Of course it's a value judgment, but I think getting that data is extremely valuable even if it had shown what we expected.
twofish-quant said:The revolutionary part was that Perlmutter came up with numbers that cannot bet explained without really weird stuff happening. Even if it turns out that the universe is not accelerating, the way that we thought the universe worked in 1997 just will not work with his observations.
Agreed, so again, give him the Nobel for what he did, not some particular inference.
