Perturbation Theory - Shift of Ground State
The discussion focuses on using leading order perturbation theory to calculate the ground state energy shift of hydrogen due to a specified perturbation. Participants emphasize the importance of identifying a dimensionless parameter for expansion and rewriting the Hamiltonian in a suitable form. The first order corrections to the energy and wavefunction are outlined, with a specific equation provided for calculating the first order change in energy. There is a suggestion to reference textbooks for additional guidance on time-independent perturbation theory. The conversation concludes with a reminder to ensure the validity of perturbation theory by selecting an appropriate small parameter.
Fraktal
Use leading order perturbation theory to calculate the ground state shift of hydrogen due to perturbation: \hat{V}
1. Leading terms in expansion of energy:
E=mc^{2}+\frac{p^{2}}{2m}-\frac{p^{4}}{8m^{3}c^{2}}+...
2.
\hat{H}=\hat{H}_{0}+\hat{V}
where \hat{H}_{0} is the Hamiltonian and the leading correction:
\hat{V}=-\frac{\hbar^{4}}{8m^{3}c^{2}}\Delta^{2}
Other useful equations:
1. \left(\psi_{1},\Delta^{2}\psi_{2}\right)=\left(\Delta\psi_{1},\Delta\psi_{2}\right)
2. \psi_{0,0,0} is a solution to the relevant stationary Schrodinger equation.
Not sure where to start with this!
First of all, you need to identify a dimensionless parameter that you are expanding around in perturbation theory. Then you need to dig through your notes or text for some more relevant equations dealing with the expansion of the perturbed states and energy levels in terms of those of the unperturbed quantities.
Still don't know how to be doing this :frown:
Found another equation (not sure how useful it is) for the corrections to the Hamiltonian:
\hat{H}=\hat{H_{0}}+\hat{H_{k}}+\hat{H_{S}}
Where \hat{H_{S}} represents the spin-orbit Hamiltonian. I have what \hat{H_{k}} and \hat{H_{S}} are but haven't shown those here at the moment since don't know if/how they're useful and are quite complicated expressions. I see that \hat{H_{k}} corresponds to the 3rd term in the expansion previously shown, but not sure quite how that's useful.
I just don't get how to do this perturbation stuff.
I can guarantee that there's a section on time-independent perturbation theory in your textbook. You want to rewrite your Hamiltonian in the form
\hat{H} = \hat{H}_0 + \lambda \hat{H}^{(1)},
where \lambda is a small, dimensionless constant. To do this, it might be convenient to note that the average momentum of the electron is small compared to its mass (times c). Therefore \lambda is conveniently written in terms of a ratio of a scale corresponding to the average momentum over the mass. \hat{H}_1 can then be written in terms of \hat{V}.
You really should find the relevant discussion of PT in your text, but the basics of the first order correction are that the expansions in \lambda of the ground state wavefunction and energy eigenvalue are
E_0 = E_0^{(0)} + \lambda E_0^{(1)} + \cdots ,
\psi_0 = \psi_0^{(0)} + \lambda \psi_0^{(1)} + \cdots ,
The superscripts correspond to the order in the expansion in powers of \lambda and the question is asking you to compute E_0^{(1)}. You should try to find the relevant term in the \lambda expansion of
(\psi_0 , \hat{H} \psi_0) = ( \psi_0^{(0)} + \lambda \psi_0^{(1)} + \cdots, (\hat{H}_0 + \lambda \hat{H}^{(1)}) ( \psi_0^{(0)} + \lambda \psi_0^{(1)} + \cdots) ).
Here's an attempt:
Hamiltonian:
H^{0}|n^{0}\rangle = E_{n}^{0}|n^{0} \rangle
Add small perturbation term H^{1}:
H^{0}+H^{1}|n^{0}\rangle = E_{n}^{0}|n^{0} \rangle
Input expansions for |n \rangle and E_{n} thus:
\left( H^{0}+\lambda H^{1}\right)|n \rangle = E_{n}|n \rangle
Hence:
\left( H^{0}+\lambda H^{1}\right)\left( |n \rangle+\lambda |n^{1}\rangle + .. =\right) \left(E_{n}^{0}+\lambda E_{n}^{1}+.. \right) \left(|n^{0} \rangle +\lambda|n^{1}\rangle + .. \right)
Match LHS and RHS terms by \lambda.
First order terms:
H^{0}|n^{1}\rangle +H^{1}|n^{0}\rangle = E_{n}^{0}|n^{1}\rangle + E_{n}^{1}|n^{0}\rangle
Which can use to find first order change in the energy E_{n}^{1}.
Inner product of the equation:
\langle n^{0}|H^{0}|n^{1}\rangle +\langle n^{0}|H^{1}|n^{0}\rangle = \langle n^{0}|E_{n}^{0}|n^{1}\rangle + \langle n^{0}|E_{n}^{1}|n^{0}\rangle
Using \langle n^{0}|H^{0}=\langle n^{0}|E_{n}^{0} and \langle n^{0}|n^{0}=1 hence:
E_{n}^{1}=\langle n^{0}|H^{1}|n^{0}\rangle
This gives the first order change in the energy state, due to the perturbation.
Not sure if that makes sense, and is correct or even relevant.
That's right. You should still try to identify a suitable \lambda in order to argue that perturbation theory is valid.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
