*pervect - Local Lorentz Frame
In summary, Peter believes that there is more than one way to determine if spacetime is locally flat.
pmb_phy
2,952
Hi pervect
I was going to put this material in the thread where we discussed this topic but I'm unable to locate that thread. Sorry for the unorthodox creation of a new thread for this. I just thought it was important to talk about. :)
I've been thinking hard about our discussion about the term "Locally Flat" [See? I do listen carefully to what you and most others say. :) ]. I looked this up in MTW and turned to page 217. Do you hold that MTW are describing locally flat coordinates or locally flat spacetime? Do you agree or object that MTW are correct and/or are better understood than "locally flat coordinates", and whatever Hillman called it, etc. If you read box 1.3 on page 20 then I think you'll agree that there is no difference between what I said and what Hillman said.
I also recall someone asking about the definiton of "Local" is defined in "Differential Geometry," Erwin Kreyszig, page 2
A geometric property is called local, if it does not pertain to the geometric configuration as a whole but depends only on the form of the configuration in an (arbitrary small) neighborhood of a point under consideration. For instance, the curvature of a curve is a local property.
Best regards
Pete
As far as I could tell, in the referenced pages MTW uses the terminology "locally lorentz frames". They also mentioned that said observer was in a "curved space-time.
If you read box 1.3 then you'd have seen that "Local Lorentz Geometry" is probably what we both have in mind and under that subsection (II) MTW give both a coordinate free language and one with a "language of coordinates." The former was what I'm used to thinking and that latter is what you seem to prefer. To me it appears to be two different descriptions of the exact same thing, i.e. Local Lorentz Geometry.
Pete
When GR claims that spacetime is 'locally flat' that means the metric can be made Minkowski and the Christoffels made vanish AT A POINT i.e. in appropriately chosen local coordinate system around that point.
My interpretation of the term 'local' is a statement that depends on a function and it's derivatives evaluated at the same local point, not on the function/derivative at different points or the function integrated over points etc.
For a free-fall/inertial observer, it is possible to turn the metric to Minkowski and nullify all Christoffels ON his worldline. That produces the physical local coordinate system used by the observer.
For an accelerated observer, exactly ON his worldline and along the whole wordline, it is possible to turn the metric in Minkowski by using the physical local coordinate system of the observer but it's not possible to nullify all the Christoffells in that system. Section 13.6 in MTW.
A sinlge point has no metric smallphi.
Furthermore, you can also have a spacetime that is flat over an extended region. Think about a flat plain between two mountains.
Yes! I fully agree!
Pete
pmb_phy said:
Yes! I fully agree!
Pete
I believe there is another way to determine local flatness and that's to use parallel transport around a closed loop surounding region of spacetime. The displacement from bringing the transported vector around such a region is determined by the Riemann tensor, which always has a non-zero value at any given point where there is spacetime curvature. However we measure differences in parallel transported vectors and not the Riemann tensor. It is always possible to make the loop small enough so that any change in the transported vector is beyond the precission of the deivices used to make measurement.
Pete
FAQ: *pervect - Local Lorentz Frame
What is a pervect in a local Lorentz frame?
A pervect is a vector that is parallel to the velocity of an observer in a local Lorentz frame. It is a mathematical concept used in special relativity to describe the relationship between objects in motion and their frames of reference.
How is a pervect calculated in a local Lorentz frame?
A pervect is calculated by taking the velocity of the observer and multiplying it by the Lorentz factor. This factor accounts for the effects of time dilation and length contraction in special relativity.
What is the significance of pervect in special relativity?
Pervects are important in special relativity because they help us understand the relationship between objects in motion and their frames of reference. They also allow us to make accurate calculations and predictions about the behavior of objects in a relativistic context.
Are pervects only used in special relativity?
No, pervects can also be used in general relativity to describe the motion of objects in curved spacetime. However, they are most commonly used in the context of special relativity.
Can pervects be observed or measured in real life?
No, pervects are a mathematical concept and cannot be directly observed or measured. However, their effects can be observed in phenomena such as time dilation and length contraction.
