PF Photography: Tips, Tricks, & Photo Sharing
In summary, PF Photography offers valuable tips and tricks for improving photography skills and techniques. They also provide a platform for photo sharing, allowing photographers to showcase their work and receive feedback from others in the community. From beginner tips to advanced techniques, PF Photography has something for every level of photographer. Additionally, their photo sharing feature encourages collaboration and growth among photographers. With a focus on education and community, PF Photography is a valuable resource for anyone looking to improve their photography skills and connect with other photographers.
  • #1,191
Andy, I was manually focusing as the auto-focus just wasn't working very well. I was focusing by looking through the view finder (mirror down obviously). I tried focusing using live view but the LCD's on cameras just don't have enough resolution. No shutter release cable, just a 12s delay. I highly doubt its mechanical vibrations. I've used the same mount and setup several times with other cameras at similar focal lengths and never had any issues.
  • #1,192
Topher, did you consider to leave everything manual and make several exposures whilst mechanically turning the focus ring some increments every time?
Also in 30 seconds exposure time, that cosmos above you does rotate a little. Maybe also try ISO 6400 and a few seconds?
  • #1,193
Andre, yes, that's basically how I got the above picture. Just took several shots at slightly different focal points.
The camera is on an equatorial mount with a relatively decent polar alignment. There shouldn't be much of any star trails with a 30 second exposure.
  • #1,194
FWIW, when I use the camera timer (even the setting that raises the mirror before 'exposing' the CCD) instead of a cable release, my star images also look fuzzy.
In any case, I am unfamiliar with an equatorial mount- does it actively move to keep the stars in position? How does it move?
Oh- the blur spots appear circularly symmetric- is that correct? Does their appearance change over the field of view?
  • #1,195
Indeed tripods may not be as stable as you want them to be. Anything around in the environment that could cause vibrations?
But Topher, you'd want to exclude that it's the lens giving the problem, so I would make a lot of test shots of the horizon in bright light, auto and manually focussed with wide open aperture.
  • #1,196
Here's a stack of 80 0.4" exposures of the Orion nebula taken at 800mm f/5.6, ISO 1250
http://img526.imageshack.us/img526/6885/orion1crop.png
The image was severely cropped and shown here at 25% scale. I can resolve the four main stars in the Trapezium, but I'm still working on getting both the nebula and the resolved stars at the same time in the final image.
I'm sure I can get a better image than this with better seeing conditions.
  • #1,197
Andy, I think that it is somewhat noisy. Otherwise fantastic.
  • #1,198
Thanks- I keep trying to pull out the faint portions of the nebula...
  • #1,199
Try keeping ISO 800.,Decreasing shutter and increasing aperture by 1-2 stops.
  • #1,200
I generally shoot astronomical and near-earth objects (satellites, etc) with a fully open aperture. It helps that the weather is cooler now, the camera noise is noticeably lower and the sky seems darker as well.
  • #1,201
Maybe consider looking at the sweet spot idea.
That's the reason why I basically avoid full open aperture unless required for available light or bokeh. Most of the time, generally speaking, you hit the sweet spot, stopped down about two clicks and before diffusion sets in, giving a rather tight range for best aperture. 5.6 is a magic number.
  • #1,202
How do you find this one?
  • #1,203
It is true that aberrations (except distortion) decrease with decreasing aperture. But sometimes I need the biggest 'light bucket' I can get.
  • #1,204
A path through the woods near my house.
  • #1,205
Very picturesque.
  • #1,206
Amal, I like yours too.
  • #1,207
A question about image gathering from satellites in LEO, as used on Google Maps etc.
This is prompted by PF thread about a research paper where data about animals (cows and deer) was derived from images on Google Maps, and the paper claimed surprising (and not obviously believable) results.
Just for fun I looked at some Google Maps images of an area that I know well on the ground, which should have contained shown plenty of fields with cows and sheep - except there were virtually no animals visible on the images, and the few that were there (about 1% of the number I expected to see) were very blurred. Also there were also no vehicles on any of the roads, which is very improbable. (Cars that were obviously parked, near buildings etc, were clearly visible)
There was no problem about the image resolution at the highest zoom level (e.g. white painted road markings and even overhead power cables were clearly resolved), so I wonder if there is something about the image gathering technology which can't resolve moving objects, or filters them out. Long exposure times, because of the extreme telephoto lenses, for example? I couldn't find anything relevant the Web.
I'm specifically asking about satellite images here. Apparently in urbanized areas aerial photography is often used to give better resolution, and that does show road traffic, etc.
  • #1,208
I doubt there is plenty of time to take these pictures - after all, these satellites are rather low and fast. Usually I see plenty of cars - perhaps pictures were taken early, like 5 a.m., before the traffic started?
But then perhaps pictures are taken in some counterintuitive way (three line sensors using the same lenses?) and then postprocessed to get rid of artifacts of the moving objects? Just guessing here.
  • #1,209
Some images were clearly in sunlight with the sun high in the sky. From the farming activity visible they were probably taken in June. So I don't think the time of day explains the lack of road traffic.
  • #1,210
Interesting... I never thought about this, but looking at NYC, around Times Square, using Google maps and Terraserver shows very few cars and people- much fewer than I would expect. The problem is not acquisition times- there are cars driving and people walking. The images may have been taken at odd times of day, but the shadows all seem to indicate 'normal' times.
Since the maps are generated based on many images, perhaps the images are chosen specifically to minimize the number of people/animals- images acquired in winter, for example?
  • #1,211
Looked around a bit in my area, no traffic jams but certainly a lot of traffic at certain places.
Keep in mind that the orbits of these (this) satellite is rather rigid. So it can only make a picture of a certain area at a certain time and the next picture weeks? months? later. Then it's visible light, so there must be no clouds. For some area's that's very rare, but the least amount of clouds are in the early morning shortly after sun rise, before convection kicks into produce cumulus clouds.
So I can imagine that having a decent picture of certain areas is a tough job in the first place, and the amount of traffic would hardly be a selection factor. Maybe that summer pictures made at something like 5-6 am, minimizing clouds, are more often successful. Probably not a lot of activity then.
  • #1,212
The lack of traffic is a bit of a side issue, but it struck me as being rather odd. The "invisible sheep" would have been in the fields at any time of day or night. Granted some of the cows might be out of sight being milked in early morning and evening, though.
  • #1,216
Amazing. The photo's too good.
  • #1,217
Relatively cold here with a strong easterly wind do curious things to reed sticks at the lake before the water freezes over:
This is straight from the camera:
http://dl.dropbox.com/u/22026080/Natural%20ice%20sculpture_1.jpg
after some tone mapping and cropping:
http://dl.dropbox.com/u/22026080/Natural%20ice%20sculpture_.jpg
Edit: Same spot looking in another direction:
http://dl.dropbox.com/u/22026080/Natural%20ice%20sculpture2.jpg
Likes 1 person
  • #1,218
Maybe it's not photography exactly, but my lab class is making holograms this month, using a kit (http://litiholo.com/). I had no idea how well the kit would work, but the students made some really nice holograms and enjoyed the process, so I thought I'd give it a try myself. I decided to try making a hologram of a computer chip:
http://img42.imageshack.us/img42/7021/dsc1626.png
Here's the hologram of the 'bare' chip:
http://img821.imageshack.us/img821/4233/dsc4757.png
It's *really* bright- I had to use a polarizer to cut the intensity down enough to take a photo. The next step was to make a hologram of the chip as viewed through a microscope objective:
http://img217.imageshack.us/img217/8514/dsc4741.png
And here's the result:
http://img85.imageshack.us/img85/4986/dsc47681.png
Not bad for a toy kit!
  • #1,219
Here's my final hologram:
http://img192.imageshack.us/img192/1710/63mm2.jpg
The object is a computer chip, magnified with a 63mm Luminar. The holographic plate was placed near the back pupil plane, producing a virtual image at infinity. This image was taken with a 85/1.4, and since the virtual image is far away, the optics table etc. is out of focus.
There's quite a bit of optics involved with doing something like this- very non-trivial.
  • #1,220
Today was the second half of an experiment- a professor from the Art department gave a special demo to my class. He turned a colleagues room into a camera (a camera obscura). It's really cool. Here's a couple images showing downtown Cleve-o, looking north to Lake Erie:
http://img252.imageshack.us/img252/8986/dsc93241filtered.jpg
http://img687.imageshack.us/img687/8324/dsc93251small.jpg
  • #1,221
Very nice!
  • #1,222
Got some excellent shots of the ISS (space station) during tonight's flyover. Easy-breezy: I set the exposure by Venus (magnitude -4.7 vs. ISS @ -2.4, so I doubled the ISO to compensate) 800/5.6, 1/500s ISO 250, no mirror lockup. Trivial to track- I took about 120 shots over 5 minutes. My card reader is at work, so I'll post a montage ASAP.
  • #1,223
Here's the whole series, no processing other than cropping and white/black levels. Seeing conditions were... "not optimal". ISS came into view from the NW and traveled approximately at a constant 40 degree elevation angle down to the SE.
http://img407.imageshack.us/img407/4131/montaget.jpg
The moral of the story is: 1) *fast* shutter speeds are essential. 2) mirror lockup isn't needed, and 3) a good tripod head is required. Even though I was only slewing at ~ 3 degrees/second, I could not have done this without a gimbaled mount- I was tracking with one hand and remote triggering the camera with the other.
  • #1,224
Here's a cleaner version- I individually adjusted each frame and deleted the 21 worst:
http://img851.imageshack.us/img851/7452/montagegoodsmall.png
I can see how the ISS rotates as it passes; it starts out with the bright main truss on the backside, and then rotates into front view. It also appears that the station is executing a roll maneuver (with respect to me) during the pass, but that could be my imagination.
Here are some external timelapse videos from a camera mounted to the ISS with some hints as to what is moving when:
  • #1,225
So just I got myself a http://www.sigmaphoto.com/shop/150-500mm-f5-63-apo-dg-os-hsm-sigma today. I did quite an elaborate research with on the shortlist also the Canon 100-400L (Turbo's lens) and the Canon 400mm F5.6L.
The Sigma won finally, due to the extended reach. As 400mm is hardly much of a gain compared to the 70-300. Maybe with tele extenders on the 400mm L, which has sufficient image quality for that, but it lacks the image stabilization.
I accepted the caveats of the Sigma, the weight and the soft image at full opening at maximum range. I tested that sort of randomly -not prepared- on these little bottles:
Oops, I did not spot that little dead bug at the time. I should have dusted first :redface:
But indeed it's soft full open as seen on this 100% crop on top:
But the bottom crop at F10 is pleasing enough to keep it. I think.
