A Phase diagram of Carbon at large electric fields.
Prathyush
TL;DR Summary
What are the phases of carbon at large electric fields.
I am wondering if the phase diagram of Carbon has been explored at very large electric fields.
Can one make any theoretical guesses ?
In specific I am interested in Pressure Vs Electric field and Electric field vs Temperature at fixed temperature and pressure respectively.
What makes you think that high electric fields would make a constructive difference ?
I would be surprised if carbon could exist for long in a high electrical field gradient.
As graphite it would conduct current and get hot due to W = I²R.
Any contamination of diamond would make it a semiconductor or resistor with a similar fate.
Carbon nanotubes or Fullerenes would probably not survive at high pressure.
I am at a very early stage of exploring this (and similar) questions. But my interest in this problem is to see if we can transition between conducting and resistive phases of carbon(or other material) by controlling electric fields.
My suspicion is that low resistance phase is unfavoured, and it will selectively crystalize into high resistance phase to minimize heat generated.
At sufficiently high pressure, my guess is that carbon will melt and begin start a crystallization process into forming a diamond. This is indeed a non-equilibrium problem because of heat flow is involved. But I am imagining heat is being steadily pumped out of the system using some cooling mechanism to lower temperature.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
