Phase shift in Mach-Zehnder interferometer
In summary, there are two different explanations for phase shifts in a Mach-Zehnder interferometer. One states that each reflection has a 180-degree phase shift, while the other states that it has a 90-degree phase shift. Both explanations can give the correct result for interference, depending on the type of beam splitter used. The rules for phase shifts are explained in classical electrodynamics, specifically in Fresnel's formulae. It is important to analyze the specific experimental setup to determine the correct explanation for the phase shifts.
Sonderval
234
TL;DR Summary
Is the phase shift 90 or 180 degree on reflection?
I'm confused by the phase shifts in a Mach-Zehnder interferometer because I keep finding two different explanations.
One explanation (for example, given on Wikipedia, but also elsewhere) states that on each reflection, the phase shift is 180 degrees, but only, if light is reflected from the front of a beam-splitter but not from the back. In this explanation, the second beam splitter is reversed (as shown on the Wiki page).
However, there are other explanations like this given here:
https://chem.libretexts.org/Bookshe...m_Computer_with_a_Mach-Zehnder_Interferometerwhere it is stated that each reflection has a 90-degree phase shift.
Both explanations work (in the sense that they both give the correct result for constructive/destructive interference), but which one is correct? Or are they both correct because it is also possible to construct mirrors with 90-degree phase shifts (for example, by choosing the correct path length in a dielectric and putting the mirror surface always at the back)?
Thanks for any help.
The correct answer is: It depends. For any symmetric and lossless beam splitter, you can easily show that the phase difference between the transmitted and reflected beam is necessarily π/2. However, not all beam splitters are symmetric. For example, the dielectric ones also mentioned in the wikipedia article are obviously not symmetric. If these are lossless, you instead arrive at a phase relation that ensures that ensures that [itex]\phi_{r,1}-\phi_{t,1}+\phi_{r,2}-\phi_{t,2}=\pi[/itex], where 1 and 2 would correspond to the red and blue beams in the wiki article, respectively.
A reasonable overview is given in this article and references therein:
https://arxiv.org/ftp/arxiv/papers/1509/1509.00393.pdf
as well as in Agnesi and Degiorgio, "Beam splitter phase shifts: wave optics approach", Optics & Laser Technology 95, 72 (2017), which is unfortunately behind a paywall.
Likes vanhees71 and Sonderval
@Aidyan and Cthugha
Funnily, the references you both provided on first sight again seemed to contradict each other - Zetie talking about 180° phase shift on reflection, Cthugha explaining that the shift is 90°
But thanks to the reference by Henault, I finally understand it: There are symmetric and asymmetric beam splitters, and in a symmetric beam splitters, the phase shift between transmitted and reflected is 90°.
Thanks for your help, that was what I needed.
Indeed, of course you have to analyze the specific experimental setup. The rules for phase shifts are explained already in classical electrodynamics. Just look up "Fresnel's formulae" in a good textbook on E&M or optics (e.g., Sommerfeld, Lectures vol. 4).
Likes Sonderval
@vanhees71
Thanks. I was just confused because my sources never mentioned that there would be alternative ways of doing it - some used the asymmetric beam splitters, some used symmetric ones, but none mentioned that both exist.
Likes vanhees71
Related to Phase shift in Mach-Zehnder interferometer
1. What is a Mach-Zehnder interferometer?
A Mach-Zehnder interferometer is a type of optical device used to measure small changes in the phase of light. It consists of two beamsplitters and two parallel paths for light to travel, with a phase shifter in one of the paths. The interference pattern created by the two beams of light can be used to measure small changes in the phase of the light passing through the phase shifter.
2. What is phase shift in a Mach-Zehnder interferometer?
Phase shift in a Mach-Zehnder interferometer refers to the change in the phase of light passing through one of the paths of the interferometer. This phase shift can be controlled by adjusting the length of the path or by using a phase shifter, and it affects the interference pattern created by the two beams of light.
3. How does a Mach-Zehnder interferometer work?
In a Mach-Zehnder interferometer, a beam of light is split into two paths by a beamsplitter. One of the paths contains a phase shifter, which can be used to control the phase of the light passing through it. The two beams of light are then recombined at a second beamsplitter, creating an interference pattern that can be measured to determine the phase shift.
4. What is the purpose of using a Mach-Zehnder interferometer?
Mach-Zehnder interferometers are commonly used in scientific research and in various industries for their high sensitivity to small changes in the phase of light. They are often used in applications such as measuring the refractive index of materials, detecting small displacements, and testing the quality of optical components.
5. What are some potential sources of error in a Mach-Zehnder interferometer?
Some potential sources of error in a Mach-Zehnder interferometer include environmental factors such as vibrations or temperature changes, imperfections in the optical components, and misalignment of the beamsplitter or phase shifter. These factors can affect the accuracy of the phase shift measurement and should be carefully controlled for in experimental setups.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
