Phasor analysis of transverse wave on a string
Phasor analysis can be applied to transverse waves on a string by isolating simple harmonic motion (SHM) at fixed positions along the string. The relationship between Young's modulus, tension, angular frequency, and frequency can be established through phasors, similar to point mass SHM. While the motion of transverse waves is oscillatory, it may not always be classified as simple harmonic under all conditions. The discussion also considers the potential for applying phasor analysis to standing waves on a string. Overall, the feasibility of this approach hinges on ideal conditions being met.
ashtadmir
The way we have a phasor analysis for a point mass executing un-damped simple SHM, is there something like that for transverse waves on a string.
According to me if we fix the position then we can focus on the isolated SHM at that particular position. Is there any way in which I can relate the young's modulus of elasticity, the tension, angular frequency as well as frequency of the whole wave to a phasor?
Can the same be done for a standing wave on a string?
PS. please explain in detail.
it wou
he motion although would b oscillatory, wouldn't be simple harmonic.
Aceix.
Aceix said:
it wou
Aceix.
I am absolutely sure that the motion will be simple harmonic (assuming the ideal conditions)
thinking of it, there is a possibility.
I am following someone on Youtube who has built a rocket shaped (4 proprllers) drone for the world speed record ... He was having problems with internal heat from electical control gear and battery inside the sealed rocket (about 1kw waste heat) Speed is 500km/hr , I suggested a 4mm hole in the tip of the nose and 8mm hole at rear which should alow sufficient air cooling .. I said this will increase thrust because the air exiting is hotter .. a bit similar to a ram jet ... was I correct...
