Physical Chemistry: Chemical Equlibrium
In summary, the conversation discusses finding the equilibrium constant and ΔG° for a reaction involving SO3, SO2, and O2 gases at a fixed volume and temperature. The ratio of SO2:SO3 at equilibrium is given and the question is how to find the equilibrium constant. Multiple attempts and equations are discussed, but the correct equation to use is not identified.
jamesrb
For the reaction:
2SO3(g) →2SO2(g)+O2(g)
when 2.00 mol of SO3 is added to a flask at 10.0 L and 350 K at fixed volume, at equilibrium the ratio of SO2:SO3 is 0.663. What is the values of the equilibrium constant? What is ΔG° at this temperature?
ΔrxnG°=-RTlnK
I cannot figure out how to find K. I'm thinking I need to find the partial pressures of the various gases in order to get it but I cannot see how to do that.
How many moles of SO2 and SO3 together? Knowing how many moles in total and the ratio, can you calculate number of moles of each?
Well if we used 2.00 moles of SO2 to start then:
1.326 moles of SO2
0.674 moles of SO3
at equilibrium
Simple check:
[tex]\frac {1.326}{0.674} \neq 0.663[/tex]
I though I could but nothing I can come up with gives me a ratio of 0.663 :mad:
What equation did you use to get the molar amounts?
Chet
I would ask "what equations" (and that's an important hint).
Related to Physical Chemistry: Chemical Equlibrium
1. What is chemical equilibrium?
Chemical equilibrium is a state in a chemical reaction where the forward and reverse reactions occur at equal rates, resulting in no net change in the concentrations of reactants and products.
2. What factors affect chemical equilibrium?
The factors that affect chemical equilibrium include temperature, pressure, concentration of reactants and products, and the presence of a catalyst.
3. How can chemical equilibrium be disrupted?
Chemical equilibrium can be disrupted by changing the conditions of the reaction, such as adding or removing reactants or products, changing the temperature or pressure, or introducing a catalyst.
4. How is chemical equilibrium represented in a chemical equation?
Chemical equilibrium is represented by a double arrow (⇌) in a chemical equation, indicating that the reaction can proceed in both the forward and reverse directions.
5. What is Le Chatelier's principle and how does it relate to chemical equilibrium?
Le Chatelier's principle states that when a system at equilibrium is subjected to a change in conditions, the system will respond by shifting in a direction that minimizes the effect of the change. This principle is often used to predict how changes in temperature, pressure, or concentration will affect a reaction at equilibrium.
