Physical meaning of open set on manifold
In summary, the definition of continuity of a function on a manifold is based on the concept of an open set. An open set is a neighborhood of all points in the space, and the map between the space and the manifold is continuous if for every neighborhood in the space, there exists a neighborhood in the manifold such that the map is contained in the neighborhood.
AlephClo
32
I understand the definition of continuity on a manifold based on open sets. I was questionning myself about what is the corresponding physical meaning of an open set of a manifold (M, Power-set-of-M, Atlas). Is it a simple (maybe simplest) assumption in order to define mathematically continuity?
Sorry I cannot help not questionning everything :-)
I am ''open'' to any reading references that can help.
Thank you, AlephClo
The definition of a topological space using open sets is the mathematically most convenient, but not the most intuitive definition. There is an equivalent definition using neighborhoods, which leads to a very intuitive definition of continuity, which closely resembles the definition in ##\mathbb R^n##. The definitions in terms of open sets can then be derived.
However, in order to define a differentiable manifold, you don't even need the concept of a topological space or continuity. There is an older (but equivalent) definition, which uses parametrizations instead of coordinate charts. The topology on the manifold (and hence the open sets) is then induced naturally. You can look it up for instance in do Carmo's book "Riemannian Geometry". It is equivalent to Whitney's modern definition, which first specifies a topological space and then equips it with an atlas. Again, the modern definition is mathematically much more convenient.
i) The definition of continuity that is used is:
The map F: M into N is continuous if for all V that belongs to Powersets(N) the preimage,f(V) is an open in Powersets(M). M and N are sets on which the differentiable manifolds are built.
ii) The particular application is General Relativity, if this can help to nail the physical meaning.
Thank you both.
Well, the purpose of my post was to make you aware of some more intuitive definitions, which are equivalent to the less intuitive definitions that you are questioning. In terms of neighborhoods, continuity of ##F## at a point ##x\in M## just means that for every neighborhood ##V## of ##f(x)##, there exists a neighborhood ##U## of ##x## such that ##F(U)\subseteq V##. A function is then said to be continuous, if it is continuous everywhere. The similarity to the ##\epsilon##-##\delta## definition of continuity in ##\mathbb R^n## should be apparent. If you define an open set to be a set, which is a neighborhood of all of its points, then the standard topology definition of continuity follows automatically. (By the way, the set of open sets is usually not the whole power set. Otherwise, the space would only admit a ##0##-dimensional manifold structure.)
However, you don't need to worry about this, if you just adopt the manifold definition given in do Carmo's book. It doesn't require any knowledge about general topology at all.
In GR, we use manifolds to generalize the idea of Minkowski spacetime to spacetimes that look like Minkowski spacetime only locally. The notion of open sets in such spacetimes just arises as a mathematical consequence of the definition. It doesn't have any physical significance, but if you study objects that look like Minkowski spacetime locally, you cannot not have open sets.
If you are interested in "physically motivated" topologies for spacetimes in general relativity,
you might be interested in https://www.google.com/search?q=Fullwood-McCarthy+topology
Some old posts:
https://www.physicsforums.com/threa...dying-general-relativity.144202/#post-1167336
https://www.physicsforums.com/threads/teaching-special-relativity.112721/#post-946181
https://en.wikipedia.org/wiki/Causality_conditions#Strongly_causal (note the comment for Strongly Causal spacetimes)
When I was in graduate school, this was a topic of interest for me. It's now on the backburner.
Rubi,
I have read the topolgical definition of neighborhoods and its equivalence to open sets, and this clarifies my question about physical meaning open sets. I will further read on Do Carmo.
Robphy,
You opened a new area of interest that I will explore.
Merci to both of you. AlephClo
Related to Physical meaning of open set on manifold
What is an open set on a manifold?
An open set on a manifold is a subset of the manifold that does not contain its boundary points. This means that for every point in the open set, there exists a small enough neighborhood around it that is also contained within the open set.
Why is the concept of open sets important in manifold theory?
The concept of open sets is important in manifold theory because it allows us to define and study the topology of a manifold. Open sets help us understand the continuity and differentiability of functions on a manifold, as well as the behavior of curves and surfaces on the manifold.
What is the relation between open sets and closed sets on a manifold?
Open sets and closed sets on a manifold are complementary concepts. A set on a manifold is closed if its complement is open, and vice versa. This means that a set can be both open and closed, or neither open nor closed.
How do open sets on a manifold relate to the concept of a metric space?
Open sets on a manifold are defined in terms of a metric space. In fact, the existence of a metric space is a necessary condition for defining open sets on a manifold. The metric space provides a way to measure distances between points on the manifold, which is crucial in determining whether a set is open or not.
What is the significance of open sets in understanding the global structure of a manifold?
Open sets play a crucial role in understanding the global structure of a manifold. By studying the behavior of open sets, we can determine the connectivity, compactness, and other topological properties of a manifold. This allows us to better understand the overall structure and geometry of the manifold.
  • Topology and Analysis
