- #71
bznm
- 184
didn't we say "all inertial frames agree on ω for the rod"?TSny said:Yes, that's right for the zero-momentum frame.
Yes, that's right. Do you see this as a problem?bznm said:didn't we say "all inertial frames agree on ω for the rod"?
TSny said:Yes, that's right *for the zero-momentum frame*.I'd say that ωθ=0 is opposite to ω0
*all inertial frames agree* on ω for the rod
I think that's correct. Most people would probably prefer to see the answer in terms of the length of the rod, L, instead of R.bznm said:so, ωθ=0 is opposite to ω0 in every inertial frame and
Umax = -2/3 ωθ=0 R cosθ + w = -2/3 ωθ=0 R + 2/3 ω0 R=4/3 ω0 R..
What about it?
Yes, that's right.[I was reading something about angular velocity: the property "it doesn't depend on an origin" is true for the rigid body (reference), but for a particle I need an origin.. isn't it?]
OK. For me, it's easier to get the initial horizontal momentum of the system (in the original frame) by just calculating the momentum of the rod since the sleeve is at rest. No need to worry about the location of the CM of the entire system.bznm said:I tried to recap everything and I think I spotted some mistakes.. could you please read it and tell me if it sounds good, @TSny ? Please!
##d_{cm}=\frac{\frac{L}{2}\cdot2M +0 \cdot M}{3M}=\frac{L}{3} ##
##v_{cm}= \omega d_{cm}##
At start the horizontal linear momentum is ##3Mv_{cm_{0}}##, while at ##\theta_{max}## rod-and-sleeve is just translating at some velocity V, so the hor. linear momentum is ##3MV##.
The potential energy expression is not quite correct. The potential energy is determined by the location of the CM of the rod.As the h. linear momentum conserves itself (there are no horizontal forces), it must be ##V=v_{cm_{0}} = \omega_{0}\frac{L}{3}##.
There are no dissipative forces, so U + K conserves.
At first (##\theta=0##), instead the motion is entirely rotational: ##E_{\theta=0}=\frac{1}{2}I\omega_0^2##, where I is the moment of inertia, calculated as ##I=\frac{1}{3}(2M)L^2##.
At ##\theta_{max}##, the motion is entirely translational, so ##E_{\theta_{max}}## is ##\frac{1}{2}(3M) V^2+ L(2M)g(1-\cos(\theta_{max}))## (where the second term is the expression for the potential energy.
Once the PE is corrected, you will get a different answer. But your method is correct.From ##E_{\theta_{max}}=E_{\theta=0}## I get ##\cos(\theta_{max})=1-\frac{5L\omega_0^2}{12g}##
OKLet's recap:
vx = -U/2 (from conservation of momentum)
##U = -\frac{2}{3}ωRcosθ##
vy = ωRsinθ
If |U| were to decrease as |θ| decreased, |vx| decreases, |ω| decreases, |vy| decreases.. that means that if |U| decreases when |θ| decreases, then KE of the system decreases, but this is not possible because also potential energy is decreasing and there are no dissipative forces. OK, we finally found out that max sleeve speed is when the rod comes back in the vertical position.
OKIf θ max, with vx the velocity in the original frame:
- in the zero momentum frame the horizontal momentum is 3M*(vx - w) = 0 i.e. w=vx (w is the transformation factor between the frames).
I conclude that w is V.
Does ##ω_{θ=0} = ω_{0}## or does ##ω_{θ=0} = -ω_{0}##?##U_{max} = -2/3 ω_{θ=0} R cosθ + w##
Due to the symmetry of motion in the zero-momentum frame ##ω_{θ=0}## is opposite to ω0 in every inertial frame and
##U_{max} = -2/3 ω_{θ=0} R cosθ + w = -2/3 ω_{0} R + ω_0 R=1/3 ω_0 R##
but then I thought that I was wrong with the calculation of px at start. In fact if I consider the system, whose center of mass is located at R=L/3, then I have to calculate px with *3*M ω R = 3M vx, so vx=ω R=ω0 * L/3=w.bznm said:In the original frame I have that px at start = px at θ max.
That is 2M ω R = 3M vx, so vx=2/3 ω R for θ max.
I conclude that w is 2/3 ω0 R.
Looks great! Good work.bznm said:##U_{max} = -2/3 ω_{θ=0} L/2 cosθ + w =1/3 ω_{0} L + ω_0 L/3=2/3 L ω_0##
About PE:
At ##\theta_{max}##, the motion is entirely translational, so ##E_{\theta_{max}}## is ##\frac{1}{2}(3M) V^2+ L/2 (2M)g(1-\cos(\theta_{max}))## (where the second term is the expression for the potential energy.
From ##E_{\theta_{max}}=E_{\theta=0}## I get ##\cos(\theta_{max})=1-\frac{L\omega_0^2}{6g}##.
Good!bznm said:Ohhh, I'm happy!
Does the symbol ##I## on the left side stand for the same quantity as the symbol ##I## on the right side? On the left side, ##I## is about what point? On the right, ##I## is about what point?but I tried writing the conservation of energy, without using special frames, between t=0 and the position in which the rod has come back in vertical position:
##1/2 I \omega_0^2 = 1/2 I \omega_{\theta=0}^2 +1/2 M U^2+1/2 (2M) v_{cm}^2##/
but if ##\omega_0=-\omega_{\theta=0}## then there's something wrong... what am I missing? :/
Uhmm, I think that the I that appears in rotational energy depends on axis of rotation.. isn't it?TSny said:Good!
OOk, thanks.. you're right as always!TSny said:At the initial instant, the rod may be considered as rotating about the top end because the top end is instantaneously at rest. So, the KE of the rod may be written simply as ##(1/2)I_\textrm{ end}ω^2##. But when the rod returns to vertical, the top end of the rod is not instantaneously at rest. Now you are expressing the KE of the rod as ##(1/2)(2M)v_\textrm{cm}^2 + (1/2)I_\textrm{cm}ω^2##.
Ok, I got it.TSny said:In the center of mass frame (zero-momentum frame), the motion is symmetric between swinging up and swinging back down. When the rod is vertical and swinging counterclockwise, the sleeve is moving to the left. When the rod reaches max angle, the rod and sleeve momentarily stop. Then, the rod and sleeve have the "reverse" motion as the rod swings back down. When the rod reaches vertical and moving clockwise, it will have the same magnitude of angular velocity as initially and the sleeve will have the same speed as initially.
It looks very good.bznm said:Could you check that my last calculation is error free?![]()
