- #36
- 8,938
- 2,947
I said that I was going to drop out, but after thinking about the model that @N88 was sketching, I realize that it is almost exactly the model Bell considered in "Speakable and Unspeakable in Quantum Mechanics". Bell didn't talk in terms of the spin vector rotating, but it amounts to the same thing:
[itex]\hat{a} \circ \vec{\sigma} = sign(\hat{a} \cdot \vec{\sigma})[/itex]
where [itex]sign(x) = \pm 1[/itex] depending on whether [itex] x > 0[/itex] or [itex]x < 0[/itex]
This model gives the correlation [itex]\langle (\hat{a} \circ \vec{\sigma})(\hat{b} \circ -\vec{\sigma}) \rangle = \frac{2 \phi}{\pi} - 1[/itex]
where [itex]\phi[/itex] is the angle between [itex]\hat{a}[/itex] and [itex]\hat{b}[/itex]. This gives the same answer as the QM prediction for the special cases [itex]\phi = 0[/itex] and [itex]\phi = \pi[/itex], but gives the wrong answer for other values of [itex]\phi[/itex]. (The quantum prediction is [itex]E(\hat{a}, \hat{b}) = - cos(\phi)[/itex])
You're not going to come up with a local realistic model that makes the same predictions as QM, because there provably are none (subject to known loopholes).
- Assume that there is an intrinsic spin vector [itex]\vec{\sigma}[/itex] associated with each spin-1/2 particle.
- If you measure the particle's spin along axis [itex]\hat{a}[/itex] then you get +1, if the angle between [itex]\hat{a}[/itex] and [itex]\vec{\sigma}[/itex] is less than 90 degrees, and -1 otherwise.
- In correlated twin-pairs, if one particle has intrinsic spin [itex]\vec{\sigma}[/itex], then the other particle has spin [itex]-\vec{\sigma}[/itex].
