I Physical Significance of Eccentricity & Semi-Latus Rectum of Orbital Ellipse
Eccentricity and semi-latus rectum are crucial for understanding the differences between elliptical and circular orbits, as they quantify the variation in distance and speed of an orbiting body. Eccentricity describes the shape of the orbit, indicating how much it deviates from a perfect circle, while the semi-latus rectum relates to the minimum and maximum distances in the orbit. These parameters are also linked to the orbital time period of planets. The discussion highlights the mathematical relationships between these quantities and their physical implications in gravitational potential. Overall, they provide essential insights into the dynamics of celestial orbits.
Clive Redwood
What are the physical significances of the eccentricity and of the semi-latus rectum of the orbital ellipse?
They're ways of quantifying how different the orbit is from a circular orbit. The physical significance comes from the fact that an elliptical orbit is physically different from a circular orbit (the distance from the center changes with time, the speed of the orbiting body changes with time).
Likes sophiecentaur
if you look up the shape of planetary orbits the eccentricity significantly describe the nature of path and the eccentricity alongwith semi latus rectum are related to the distance of minimum approach or maximum distance for say an elliptical path and in turn it gets related to time period of the planet.
Please consider the following:
Assuming a simple harmonic oscillation of the gravitational potential centered at -GM/l, and with extrema labeled 1 and 2, then:
a. the shifts in the potential are equal and opposite:
-(GM/l - GM/r1) = -(-(GM/l - GM/r2))
Dividing by GM reveals l as the harmonic mean of r1 and r2.
b. Dividing the equation above by GM/l , we get:
1/r1 -1 = 1 - 1/r2 = e
This is the magnitude of the fractional shifts of the gravitational potential. It is also the eccentricity.
c. The amplitude of the oscillation is eGM/l . So the potential at a distance r may be expressed as:
- GM/r = - (GM+eGMcosq)/l
were q is a state variable of the oscillation. This equation may be rewritten as:
r = l/(1 + ecosq)
The couple (q, r) alternates between the extrema (0, r1) and (π, r2). These are 'collinear' with the 'origin'. So assigning the quantity 2A to the 'length' between these points, we get:
2A = l/(1 + e) + l/(1 - e)
and l = A(1 - e2)
So we may express the orbital radius as:
r = A(1 - e2)/(1 + ecosq)
This is, in polar coordinates, the equation of an ellipse. For the orbital ellipse, q is the true anomaly. Also l is the semi-latus rectum and is shown here to be the orbital radius at the center of the simple harmonic oscillation of the gravitational potential.
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
