B Physical temperature and antenna temperature
The discussion focuses on the relationship between physical temperature and antenna temperature, highlighting confusion about the interpretation of temperature as it relates to energy and radiation. The participant questions whether the concept of temperature as a measure of average kinetic energy is too limited, especially in contexts like stars, where total radiated power seems more significant. They express uncertainty about the approximation of energy density being constant at kT_P and its implications for understanding radiation. The conversation suggests that studying blackbody radiation and its energy distribution could clarify these concepts. Overall, the thread emphasizes the need for a deeper understanding of how temperature relates to radiated power in physical systems.
Unconscious
I have read some documents on the subject, but until now, unfortunately, I still do not have a good understanding of them, most likely due to personal shortcomings that start from physics. In this regard, I would like to try here to expose some doubts that will almost certainly appear very stupid and basic, however I hope that someone has patience in helping me.
I refer to this document (if there is a better one, please tell me): https://www.ece.mcmaster.ca/faculty/nikolova/antenna_dload/current_lectures/L07_Noise.pdf
I start slowly, without immediately messing up an infinite number of questions. In the first paragraph I am told that a body at a physical temperature ##T_P##, by the mere fact of being at that temperature, has a spectral density of energy (for now it is not even said that it is energy that manifests itself in the form of radiation electromagnetic towards the outside) which is constant and equal to ##kT_P##, with k the Boltzmann constant having the value it has surely for deep physical reasons that I would not go into now. From here I immediately asked myself:
1. is it already an approximation? If this were not the case, every body would have infinite energy;
2. up to now, I have always translated in my head "a body is at temperature ..." with the picture "the average kinetic energy of the elementary constituents that compose it is equal to ...". Reading this document I am doubting that this picture is a bit too limited, because if I think of a star (towards which I can point an antenna) it does not seem reasonable to me that the physical quantity temperature should be interpreted as the average agitation of its elementary constituents, but more like something that is directly related to the total power it radiates (which I will have to worry about knowing how to measure, but for now I suppose I can).
If so, it almost seems that the only thing that has real physical significance is the total radiated power, thus saying that the temperature is that physical quantity that I define starting from the radiated power. And this confuses me, because it seems that you could have avoided this artificial construction and immediately speak in terms of power. What is the right way to see things? Thanks to those who want to try to help me on these simple matters.
It sounds like you should study the blackbody. Especially the part about a cavity with a hole. It starts with the idea of a container with walls at a certain temperature, and then continues with analysis of what happens to radiation bouncing off those walls. Eventually, the energy distribution of the radiation depends on the temperature of the walls. You can say that the energy distribution of light leaking out is an indirect way to measure the temperature.
https://en.wikipedia.org/wiki/Black_body#Idealizations
Thank you, I will read again with this in mind. Surely, I will come with other questions.
kTp is the power per unit bandwidth.
It is an approximation for low frequencies, up to Infra Red say. It does not agree with the spectral curves for optical and shorter wavelengths.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
