MHB Physics - Archimedes principle
The discussion centers on applying Archimedes' principle to determine the proportion of a wooden board that floats above the surface when placed in the Dead Sea. The user is confused about calculating the volume since only the area of the board is provided. It is clarified that the dimensions can be simplified as they cancel out in the ratio of submerged to total volume. The final calculation indicates that approximately 35% of the wood floats above the surface. Understanding that the area and density ratios suffice for the calculation is key to solving the problem.
bigpoppapump
Im having trouble with the following question regarding Archimedes principle.
A wooden board with an area of 4.55m^2 is dropped into the dead sea (P sea- 1240 kg/m^-3). Calculate the proportion that would float above the surface. (P wood - 812 kg/m^-3).
My understanding is that the volume (V sub) of the submerged object over the total volume (V) of the object is equal to the density (P wood) of the Object over the density (P sea) of the water.
Because the question has given me an area and not a volume or even dimensions to calculate the volume, i am confused as to how to complete the question.
Mathematics news on Phys.org
$$\dfrac{4.5 \cdot d}{4.5 \cdot h} = \dfrac{812}{1240}$$
where $d$ is the submerged depth of the wood and $h$ is the physical height of the wood
note the question being asked is the proportion of the wood that floats above the surface …
$$\frac{h-d}{h} = 1-\frac{d}{h}
Thank you. So by my calculations, this would have 35% floating above the surface.
The point is that you don't need to know the other dimensions- they cancel out of the fraction:
$\frac{V_{sub}}{V}= \frac{d_{sub}A}{dA}= \frac{d_{sub}}{d}$
where V is the volume of the stick, $V_{sub}$ is the volume of the submerged part, d is the thicknes of the stick, $d_{sub}$ is the thickness of the submerged part, and A is the cross section of the stick which is the same both submerged and not submerged.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
