I Physics behind making a mango milk shake
  • I
  • Thread starter Thread starter starpower1824
    Centrifugal Physics
The discussion focuses on the working principles of a mixer grinder used for making a mango milkshake. It outlines the process of preparing the ingredients, including slicing the mango and combining it with milk and sugar in the mixer. The conversion of electrical energy to mechanical energy by the mixer motor is explained, detailing how the rotating blades create centrifugal force that affects the ingredients. The vacuum created in the container leads to a differential air pressure, allowing the mango and sugar to mix thoroughly while noting that denser ingredients like rolled oats may not blend as well. Overall, the explanation captures the essential physics involved in the mixing process while acknowledging the complexities of fluid mechanics.
starpower1824
TL;DR Summary
Trying to put into words the working principles of a mixer grinder
Hi Folks!I have limited understanding of physics. I am trying to put into words the working principles of a mixer grinder, specifically for making a mango milkshake. So far, these are the steps I have come up with:
  1. You are craving mango shake. You have raw mango, raw milk and sugar.
  2. You slice up the mango in smaller pieces so that it's easier for the mixer to do it's job.
  3. You put that in the mixer container and pour in the milk and the sugar as required.
  4. You close the lid and attach the container to the mixer main body. You turn on the switch.
  5. The electrical energy carried by the AC current from "mains" is converted into mechnaical energy of the mixer blades by the mixer motor. The blades soon attain a stable speed depending on the speed configuration that you can set with something like a knob.
  6. The blades are pivoted, and as they rotate they cause the ingredients directly in contact with them to rotate due to friction. That rotation motion is passed on to all the ingredients which are in contact due to gravity and molecular forces.
  7. All the ingredients start rotating, and experience a centrifugal force which forces them to move to the extremes of the container since there's no opposing force. This causes a vacuum of sorts in the middle cylindrical region of the container.
  8. The vacuum results in a differential air pressure, which causes air to try to rush into the middle, resulting in a previously non-existent force in opposition to the centrifugal force. If an ingredient is not tightly bound, part of it might break off and fly into the middle.
  9. So the mango breaks into tiny pieces, small enough to mix into the milk and seem like a homogenous mixture. Same thing probably happens with sugar. If you put in another "more solid" ingredients like rolled oats, they'll break into smaller pieces but not neccessarily small enough to mix with milk and will probably settle at the bottom once the mixer is stopped.
  10. And your mango milk shake is ready!
Where am I wrong? What things have I gotten right?
Thanks!
Welcome to PF. :smile:
Is this for a schoolwork assignment? If so, I can move your thread to the schoolwork forums for you. Also, what references have you been reading to try to figure this out? It seems like the blade shape makes a big differency in the liquid/solid mixing vortices and chopping action.
The physics are electromagnetism , mechanics(for the motor that as you said converts electrical power to mechanical power) and fluid mechanics (for the air that surrounds the rotating milk mix and the rotating milk mix).
I believe you do a good work in describing in a qualitative way what is happening but if we are going to write down some equations we going to get lost, especial in the fluid mechanics part.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
