Physics Concepts Force and Work Help
The discussion focuses on understanding energy types related to physics concepts, specifically in the context of a spring scale and a winding watch. Weighing something on a spring scale involves gravitational potential energy and elastic potential energy due to the spring's deformation. Winding a watch converts chemical energy from food into kinetic energy, which is then stored as potential energy in the watch's spring. The efficiency of a machine increases when work against resistance or friction is reduced. Lastly, the amount of work is not decreased by multiplying effort needed or effort distances, as both factors influence the total work done.
x0ji11y
1. What type of energy is involved in weighing something on a spring scale?
2. What type of energy is involved in winding a watch?
3. Is a machine's efficiency increased if the work done against the resistance force is decreased or if you decrease the work against friction?
4. Is the amount of work decreased if the efforts needed are multiplied or if the effort distances are multiplied? (either, both, or neither).
F=ma
I cannot seem to grasp these concepts! Any help would be greatly appreciated! :)
i prefer to help people understand the concept than flat out tell you the answer, so ill give you some pretty substantial help with 2. because that is a good starting point.
when YOU wind up a watch you are effectively giving it energy to "work" for a period of time in the future. assuming youre winding a pretty old watch they have a spring inside that helps keep the time.
Now you as a person has to actually wind the watch, and in order to create the energy used by your body you eat food, which then releases chemicals into the body and these chemicals are used, so the first step is CHEMICAL ENERGY.
you are then using this chemical energy to power your fingers to wind the watch, therefore creating KINETIC ENERGY or movement.
this then transfers into the watch to keep it ticking. seeing as this energy is stored by the spring in the watch you have given the watch POTENTIAL ENERGY, so that it can continue working into the future.
hopefully this has broken it down enough for you :)
hit back if you need more help
Thanks for the help! Now, would weighing fruit on a spring scale be elastic potential energy also? That was my initial thought, but I then realized that the main focus on a scale is the mass, which is only in an equation for GRAVITATIONAL potential energy...
there would be elastic potential, and i would suppose that if the spring balance was above ground it would have gravitational potential too, but i don't think that its key to state it as part of the answer to that question.
The main focus of the scale is mass, and the mass being pulled by gravity exerts a downward force on the scale, thus stretching the spring and giving it elastic potential
Thank you sooooo much for all of your help! I think I understand these concepts now :)
no worries :)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
