Physics: conservation of energy and springs
The discussion focuses on a physics problem involving two children using a spring-loaded gun to hit a target box with a marble. Bobby's attempt falls short, prompting the need to determine how much Rhonda should compress the spring for a successful hit. Key concepts include the conservation of energy, where the potential energy stored in the spring is converted to kinetic energy of the marble, and the kinematic equations for projectile motion. The time of flight is constant due to the height from which the marble falls, meaning the horizontal distance traveled is directly related to the marble's horizontal speed. The conclusion emphasizes using conservation of energy and projectile motion equations to solve for the required spring compression.
InFiNiTeX
Two children are playing a game in which they try to hit a small box on the floor with a marble fired from a spring-loaded gun that is mounted on a table. The target box is 2.20m horizontally from the edge of the table. Bobby compresses the spring 1.10cm, but the center of the marble falls 27.0cm short of the center of the box. How far should Rhonda compress the spring to score a direct hit? Assume that neither the spring nor the ball encounters friction in the gun.
i know i use conservation of energy and X=vt+(1/2)Axt^2 and Y=Voy(t)+(1/2)Ayt^2 and i think you solve for both... but after that i don't know what to do... am i using the right equations? the answer is 1.25cm
Realize that the time it takes for the marble to fall depends only on the height so is a constant. Thus the horizontal distance the marble travels is proportional to its horizontal speed. Now relate the horizontal speed to the amount of spring compression using conservation of energy: 1/2 k x^2 = 1/2 m v^2. Use ratios.
i do not really understand... i was told i would most probably use conservation of energy and the 2d motion equations.. is that the same as what you explained?
Realize that there are usually several ways--all equivalent--to solve these kinds of problem. I don't know what you mean by "2d motion equations"; I assume you mean the kinematic equations you wrote? If so, realize that only the vertical motion is accelerated; the horizontal speed remains constant.
Bottom line: Yes, use conservation of energy and kinematics of projectiles.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
