Physics Help Greatly Appreciated - Block sliding down ramp
A 7.7 kg block on an incline with a coefficient of static friction of 0.50 begins to slide when the angle reaches approximately 26.6 degrees. The initial attempt to calculate the time for the block to slide 0.47 m used an incorrect assumption of zero friction, leading to an acceleration of 4.39 m/s². Correcting for friction, the force balance equation reveals the actual acceleration to be 1.41 m/s², resulting in a revised time of 0.82 seconds to slide down the ramp. Participants emphasized the importance of the student performing the calculations independently while providing guidance. The discussion highlights the significance of accurately accounting for friction in physics problems.
Engineering101
Physics Help Greatly Appreciated -- Block sliding down ramp
A 7.7 kg block is on an incline with a coefficient of static friction of 0.50. The angle that the ramp makes with the horizontal is increased gradually, until the block begins to slide down the ramp. If you know that the coefficient of kinetic friction between the block and the plane is 0.34, find the time it will take the block to slide down the ramp a distance of 0.47 m starting from rest.
Ff=uFn
My solution:
arctan(.5)=angle of incline=26.6degrees
a=2x/t^2 (rearranged kinematic equation)
a=gsin(26.6)
a=4.39 m/s^2
4.39=2x/t^2
x=.47m
.94/4.39=t^2
t=.46 s
(This solution was marked incorrect) Help would be greatly appreciated.
It seems to me that you have calculated the time it would take if the coefficient of kinetic friction were zero.
Vic is correct. Letting the acceleration = gsin(theta) gives the acceleration in the absence of friction. If you look at the force balance in the down incline direction it should read:
Ffriction + Fgravity = ma (1)
<< some extra work deleted by Mentor >>
Solve that to find the acceleration and the re-evaluate your kinematics equation.
Chris.
Chris.
Thanks for being willing and able to help with this question, Alexander. Just please remember that the OP student must do the bulk of the work. I think with the hints that he's been given now, he should be able to show us his work toward the correct solution.
Thanks for the help! I genuinely appreciate it :)
I used
Fg-Ff=ma
mgsin(26.6)-umgcos26.6)=ma
9.8(sin26.6)-.32cos(26.6)=a
a=1.41
t=.82s
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
