Physics help using Work-Energy theorem
The discussion focuses on a physics homework problem involving the work-energy theorem to determine the minimum speed needed to push a box up an incline with friction. The box has a mass of 2.60 kg, a slope angle of 30 degrees, and must reach a height of 3.10 m. The participant attempts to set up the equation Ki + Ui + Wother = Kf + Uf, but struggles with calculating the work done by friction accurately. They calculate the gravitational potential energy (Uf) as 39.5343 J but are unsure about the frictional work (Wother), leading to incorrect final speed results. Assistance is requested to clarify the calculation of frictional work and to analyze the forces acting on the box.
ochatesme
You are a member of an alpine rescue team and must get a box of supplies, with mass 2.60 kg, up an incline of constant slope angle 30.0\circ so that it reaches a stranded skier who is a vertical distance 3.10 m above the bottom of the incline. There is some friction present; the kinetic coefficient of friction is 6.00×10^{-2}. Since you can't walk up the incline, you give the box a push that gives it an initial velocity; then the box slides up the incline, slowing down under the forces of friction and gravity. Take acceleration due to gravity to be 9.81 m/s^{2}.
Use the work-energy theorem to calculate the minimum speed (v) that you must give the box at the bottom of the incline so that it will reach the skier.
Given that the problem revolves around the work-energy theorem I have set up an equation which I pulled from problems that were very similar to this one out of the textbook. I ended up with Ki + Ui + Wother = Kf + Uf, where K is kinetic energy, U is the gravitational potential energy and Wother is the force of friction in the system. The "i" in the equation stands for the initial position of the box at the bottom of the slope and the "f" in the equation is for the final position when the box has reached the top of the slope after overcoming friction.
I made several attempts at this solution and I'll try my best to explain exactly what it was that I did, maybe you guys can help point out some of the errors I made because I am sure they are there. Given that Ui is at the bottom of the slope and there is no displacement in the vertical direction, I made that part of the system "0". I also made Kf "0" due to the fact that at the final position of the box at the top of the slope, the box no longer has kinetic energy. Thus far my equation looked something like this "Ki + 0 + Wother = 0 + Uf". After this, I calculated Uf to be 39.5343 J. One of the steps that I think I'm really messing up on is calculating the amount of work done by the force of friction, what I'm doing on this step is taking the coefficient of friction and multiplying it by the normal force, which ends up looking like (6.00 x 10^-2)(2.60kg)(9.81m/s^2)(sin30) which calculates out to 0.76518 J. When I plug all this back into the original equation to try to solve for V I end up with the wrong answer each and every single time. I'm 100% sure that the mistake I'm making comes when I'm making an attempt to calculate the work required when going through the force of friction. Thanks in advance for your help!
Someone...anyone? If someone could lead me in the right direction in figuring out how to calculate the work done by the force of friction (W other) I would really appreciate it!
First analyze the forces acting on the box of supplies as it moves up the incline.
Show me your free body diagram.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
