Physics problem about Earths rotation after 45 centuries
  • Thread starter Thread starter wbetting
    Physics Rotation
The discussion revolves around calculating the total increase in time due to Earth's slowing rotation over 45 centuries. The initial calculation yielded an incorrect total of 617 hours, prompting a reevaluation of the approach. Key corrections include using 365.25 days per year for more accuracy and converting seconds to hours correctly. The final calculations suggest that the total time increase is approximately 0.01 hours, or just over 30 seconds. The use of a graph to visualize the time increase over days is also recommended for clarity.
wbetting
Because Earth's rotation is gradually slowing, the length of each day increases: The day at the end of 1.0 century is 1.0 ms longer than the day at the start of the century. In 45 centuries, what is the total (in hours) of the daily increases in time (that is, the sum of the gain on the first day, the gain on the second day, etc.)?
I have tried and tried again and i keep getting 617 hours which is wrong, please help!
45centuries*.001s/century=.045s
(0s+.045s)/2=.0225 s longer than 1st
(.0225second/day)(365day/yr)(4500yr)=36956.25 seconds
(36956.25s)*(1hr/60sec)=615.94hours
the few mistakes i can see are that you might want to use 365.25 days in a year instead of 365, and also you should do your time in seconds divided by 3600 not 60 (60 seconds in a minute, 60 minutes in an hour)
so if your time in seconds was right, you would do:
(36956.25s)*(1hr/60min)*(1min/(60sec) = (36956.25)*(1hr/3600sec) = 10.266 hours.
Probably the easiest way is to draw a graph with x-axis representing days and y-axis representing time increase (you can start y at 0 since you only want time increase). after 36525 the y value is 0.001 (keeping values in day and seconds to make things easier) and at the end of 45 Centuries y value should be .045
Find out how many days in 45 Centuries and time increase after 45 Centuries. Find the area underneath graph and that would represent time increase in ms over 45 Centuries.
My calculations show it to be just a bit over 30 Seconds (0.01 Hours which sounds about right, I think :p
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
