Physics Problems ? (particle acceleration)
The discussion focuses on two physics problems involving particle acceleration. For Question 6, the participant is trying to determine when the velocity magnitude of a particle, initially moving east at 45 m/s and accelerating north at 100 m/s², reaches 100 m/s. In Question 7, the challenge involves calculating the acceleration of a plane based on the angle of a pendulum accelerometer hanging at 11° from vertical. The hints provided suggest using vector components and free body diagrams to solve the problems, emphasizing the importance of understanding acceleration vectors. The participant expresses confusion about the equations and components needed to find the solutions.
JJ91284
I'm working on my last 2 of 30 or so physics problems and am pretty lost on what to do/how to even start. The homework is due in exactly 3 hrs, I already have an "A" on this assignment but would like to squeeze on these last 6 points or so.
Question 6
A particle experiences a constant acceleration that is north at 100 m/s2. At t = 0, its velocity vector is 45 m/s east. At what time will the magnitude of the velocity be 100 m/s?
Question 7
An accelerometer-a device to measure acceleration-can be as simple as a small pendulum. Suppose you are flying a small plane in a straight horizontal line and your accelerometer hangs 11° behind the vertical, opposite the direction of motion. What is your acceleration?
What are your thoughts so far?
Hints:
Qu #6: You're given the component of velocity in the east direction and the magnitude of the velocity at a certain time, how can you work out the north component?
Qu #7: Draw a free body diagram of the pendulum and see if you can work from there.
Question 6 I don't really understand what they are trying to get across.
So a particle is going N at 100 ms^2
So that gives me acceleration is=100 constantly
It gives me east velocity at 45 m/s at t=0 (time)
I'm assuming the North part is important, but I don't know what equation they're looking for or what in general I'm suppose to find.:rolleyes:
As far as question 7 goes, am I suppose to use gravity (9.8 m/s2) for anything. The plane is obviously accelerating because the pendulum is back 11 degrees. Just like when a car accelerates, your pushed into the seat.
I was thinking of accelerating formulas I know, and a=v/t doesn't work. I don't have velocity or time. The only component that I feel I have would be the angle which is 11 degrees. Which I don't know what I'm suppose to use that for.
I guess there were a lot of students confused on question 7 so this is what are instructor said.
HW problems from Chapter 3 Hint for Problem 7: The tension on the pendulum string has an x and y component, the y component is T cos theta and is equal to mg - use this to solve for T. The x component is balanced by the forward acceleration of the airplane - so use T sin theta - a*m to find a.
I'm going to see if I can figure it out now.
Acceleration vectors can be added together using the same math as you've been using to add velocity vectors. You do not need to really break the components up into x-y, because you already know the direction of the acceleration!
1. Due to gravity directly down (-y).
2. Due to the plane directly to the back (-x).
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
