Physics roller coaster question
The discussion revolves around solving physics problems related to a roller coaster's stopping force and deceleration. The user expresses uncertainty about their calculations for parts C and D, specifically regarding the force needed to stop a 12,000 kg car. Another participant confirms the calculations, noting that the problem lacks real-life considerations such as friction and drag. They highlight that the required deceleration would be excessively high, at 13.6 G, which is impractical. The conversation emphasizes the importance of understanding theoretical versus practical applications in physics.
meso
Consider the frictionless roller coaster shown below.( the picture Is attached below)
If a 12 000 kg car starts at rest from Point A, calculate
a) the total energy of the system
b) the speed of the car at point B
c) the force that must be applied to bring it to a stop at point E
d) the work done to bring it to a stop at point E
Eg=mgh
Ek=1/2mv^2
W=Fcos0 x d
Etotal= Ek1 + Eg1
W= delta Ek ( Ek2 – Ek1)
I am stuck at C and D. I tried to solve D by applying W= delta E
W= Etotal
F x d= 11172000
F= 11172000/7
But I am not sure if it is right
W= Etotal
F x d= 11172000
F= 11172000/7
Looks right.
The problem is not specific about the deceleration distance, but assuming the whole last 7 meters are used for stopping the 12 000 Kg car, then one needs to solve d) first in order to be able to solve c) in the way you have shown.
That is a huge stopping force.
Likes meso
I found the force required to stop the roller coaster to be 1596 000 N, but I am not sure neither confident about my solution.
Your solution is correct. :smile:
It is only that the problem is not very complying with real life.
With no resisting friction or aerodynamic drag, the speed at ground level would be 155 km/h (43.17 m/s in free-fall).
The corresponding deceleration during those 7 meters would be ##-133~m/s^2##, which equals 13.6 G, which would be too much for comfort.
Likes meso
Thanks. Also, that makes sense but I am doing physics grade 12, so they disregard some factors for the sake of this course.
Likes Lnewqban
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
