Pi meson decay (relativistic momentum)
A charged π meson decays into a neutrino and a μ meson, with the task of finding their kinetic energies. The initial energy in the rest frame of the π meson is 273mec², while the final energy consists of the μ meson's energy and the neutrino's kinetic energy. The discussion highlights the use of conservation of momentum, noting that the momentum of the neutrino is equal and opposite to that of the μ meson. The problem involves transitioning between reference frames to simplify calculations, ultimately leading to a quadratic equation for the speed of the μ meson. The solution confirms that the approach is valid and yields the correct kinetic energy values.
RyanP
A charged π meson (rest mass = 273me) decays into a neutrino (zero rest mass) and a μ meson (rest mass = 207me). Find the kinetic energies of the neutrino and the mu meson.
E = moγc2
K = mo(γ-1)c2
v = pc2/E
p = moγv
In the rest frame of the pi meson (S frame),
Ei = 273mec2
Ef = 207meγc2 + K where γ is the gamma factor of the mu meson and K is the energy (kinetic) of the neutrino.
Since the neutrino has no rest mass, it travels at c, so pv = Ev/c = K/c.
I couldn't figure out how to carry on in this frame, so I switched to an S' frame where the mu meson is at rest.
In this frame,
p'i = -273meγv where v is the speed of the pi meson initially (equal to the speed of the mu meson in the pi rest frame).
p'f = -E'nu/c since the neutrino is the only thing moving after the collision in this frame.
E'i = 273meγc2
E'f = 207me + E'nu
How do I proceed from here?
Go back to the rest frame of the pion. Since the pion is initially at rest, the initial momentum in this frame is zero. Since momentum is conserved, the final momentum is zero also. So what do you know about the momenta of the neutrino and the muon?
The momentum of the neutrino is equal and opposite to the momentum of the muon - should I solve for the speed of the muon?
You should be able to write four equations for the four unknowns, Enu, Emu, pnu, pmu.
Ended up with a quadratic equation for v (speed of the muon), in terms of both masses and c. Brute-forced it with the quadratic formula and got the right answer.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
