Piecewise Functions in the Einstein Field Equations
In summary: That I expected (although as you and @PeterDonis note, only in an approximate/idealised case). But it seems to me that continuous metric allows discontinuous first derivatives and hence undefined second derivatives and Riemann tensors. Presumably that doesn't happen (or isn't a problem) for some reason - and that's where I need to read your citation. Too sleepy now, but will look in the morning.Your understanding is correct. A continuous metric allows discontinuous first derivatives and hence undefined second derivatives and Riemann tensors. However, in practice, most problems with a piecewise function solution can be handled by using a discontinuous approximation.
Sciencemaster
105
TL;DR Summary
Can piecewise functions be used to find solutions to the Einstein field equations?
Let's say I want to describe a massive box in spacetime as described by the Einstein Field Equations. If one were to construct a metric in cartesian coordinates from the Minkowski metric, would it be reasonable to use a piecewise Stress-Energy Tensor to find our metric? (For example, having components be nonzero on the interval $-a<X_\mu<a$ and 0 everywhere else?) Can piecewise functions be used to create valid solutions to the EFE's in our universe, or is this invalid??
Likes Delta2
Yes, this is absolutely a valid approach. For example the Oppenheimer Snyder collapse solution is modeled by a radial function which is zero outside the dust cloud and non-zero inside.
Likes vanhees71 and PeterDonis
Alright, sounds good! The piecewise-ness is concerning me a bit though, would the area in the piecewise function still affect the geometry of the area outside?
"Piecewise-ness" is a not a property of a function; it simply refers to how you choose to define the function. All functions may be defined piecewise or not (if you try hard enough).
You can have piecewise polynominals, or piecewise continuous or piecewise differentiable functions. In these cases, the piecewiseness applies to a property of the function and is significant.
But, simply defining a function in a piecewise manner is not significant in terms of functional properties or the lack of any particular functional property.
Likes vanhees71 and Dale
You require that the metric at the boundary be continuous and sufficiently differentiable for your purposes (you'll need finite second derivatives for the Riemann be finite, at least). So you can see the value and derivative(s) of one at the joints between two pieces as sort of boundary conditions on the other, which is how they affect each other.
Likes vanhees71
Sciencemaster said:
Summary:: Can piecewise functions be used to find solutions to the Einstein field equations?
As an analogy, consider electrostatics. Suppose there is a uniform charge density on a spherical surface, and a vacuum inside and outside. What is the electric field inside the spherical surface? Outside? What is an expression for the charge density in terms of 3-dimensional space?
Likes vanhees71
Actually, there is a well established approach for junctions in GR which only requires continuity. They are called the Israel Junction Conditions. I can’t find a concise reference at the moment, but the following discusses them:
https://arxiv.org/abs/gr-qc/0505048
Likes vanhees71, Ibix, Dale and 1 other person
I didn't know that. It seems surprising to me because I think you'd want the Riemann to be well defined and continuity only guarantees that the first derivatives of the metric are finite everywhere. Presumably either (a) I'm wrong or (b) it comes out in the wash somewhere. I'll have a look at your reference.
Likes vanhees71
You are not wrong. The conditions allow a discontinuity in curvature. Two common cases where any simple model must tolerate this are the Oppenheimer-Snyder solution @Dale mentioned earlier, and a hollow shell of matter. In the former, you have Schwarzschild outside the dust surface. It is too complicated to require the dust density to smoothly vanish at the surface, so the solution involves a curvature discontinuity at the surface. Similarly, for a matter shell you have discontinuity from shell to schwarzschild outside, and shell to Minkowski space inside.
Likes vanhees71, Dale and PeterDonis
As a clarification, the discontinuous solutions are, I think, best viewed as useful approximations to a more physically realistic but also much more mathematically intractable solution that interpolates continuously between the two patches. This statement...
...is an example of what I mean.
Likes vanhees71
Likes vanhees71
PeterDonis said:
As a clarification, the discontinuous solutions are, I think, best viewed as useful approximations to a more physically realistic but also much more mathematically intractable solution that interpolates continuously between the two patches. This statement......is an example of what I mean.
This is pretty common in (classical) field theory. E.g., in electrostatics we consider a problem like a conducting charged sphere and just use a boundary condition at its idealized boundary, leading to a jump in the normal component of the electric field. Of course in reality there is not really a sharp surface but a "fuzzy cloud" of charges, but the solution with the idealized conditions is good enough for all practical purposes.
Likes George Jones
Alright, so the piecewise function would still need to be continuous to get a valid equation, if I'm understanding what you all are saying. For a box floating around in space, would that just mean I should use a 'fuzzy' approximation of a change in the stress energy tensor (i.e. description of matter) representing the edge of the box? Such as a^(cx) where c is very large?
Also, would anything special need to be done at the boundaries to account for there being surfaces or can I just define the inside of the box, the outside of the box, and make the piecewise functions continuous?
Also, I was going to post this in its own thread but since it's related to this question and is set up with the physical system I have already described, I figured i'd post it here. If this isn't the right place for it, please feel free to let me know.
So for an uncharged conducting box as described initially, in space and at rest in its own reference frame, I'd like to try and construct a stress energy tensor that can describe the matter and such in this situation, i.e. the box and the space around it. For clarity, when I say space, I mean the kind of space between galaxies in the real universe, where it's mostly empty, but the cosmological constant is nonzero and there is some small amount of ambient matter.
As for the box itself, the energy density is just going to be mc2 if I'm not mistaken, and the energy flux/momentum density will be zero since we are describing it in its own reference frame. However, I'm having trouble figuring out how to make valid shear stress/momentum flux indices, and figuring out what the pressure of a solid in outer space would be (especially considering that it's not expanding by it's construction, it's just sitting stationary in this reference frame). How could I describe/find these indices in such a system. I don't imagine I can just describe a conducting solid as a perfect fluid or anything even with approximating...
The usual approach would be to use a weak-field approximation. Then cartesian coordinates then make sense in the flat background assumed by the approximation. If you're not imagining a flat background approximation, you might have to say a few more words about what you really want to accomplish, there's not an exact equivalent to Cartesian coordinates in general space-times. Depending on what you want to acacomplish, you might be able to come up with something that does what you want in spite of this lack, though.
If you are thinking of something that is somehow not weak field, though, it's also be best to give a few more details of what you want to do, exactly. I will note that it will probably be hard to find a case where you need anything other than the weak field approximation. You'll also find that large enough boxes with the strengths of materials for matter we know about will pretty much have to be spherical, as materials are simply not strong enough to create a cubical planet or star, for instance.
The case of a large spherical object has of course already been analyzed with appropriate approximations. One of the wrinkles in this sort of analysis that you haven't mentioned will be the "equation of state", which relates the pressure to the density of the material composing the object.
Likes PAllen
Alright, so I'm actually considering a small box on the stellar scale, the kind we might see in our experience. I'm trying to construct a collection of regions that have different substances in them so that I can see how a path through them is affected by the warping of spacetime, however small it would be. An example of what I'm thinking of is a cube filled with air and the path of a neutrino moving through it, where we may be able to approximate the oxygen as an ideal gas. On this scale however, I imagine we should take into account the ambient matter of the universe, especially if using substances that reach that density.
Using a sphere will simplify things from the additional symmetry.
I'm sure it will, but it doesn't really satisfy the geometry I had in mind...
At any rate, would I just be able to use a continuous, piecewise geometry to create a boundary (as in, not having to make it continuously differentiable or meet any other prerequisites)? I want to make sure this is something I can actually do.
Is non-spherical geometry essential? This is the first time you mentioned it.
Make sure that the non-spherical geometry is truly essential before going down that route. The difference in mathematical complexity is vast. If you don’t have a truly solid reason for a different geometry then you should reconsider. Certainly you have not expressed such a reason in this thread.
Has anyone been ambiguous in any way? The answer is, yes. Why do you need it repeated?
You're right, I apologize. Yes, a non-spherical geometry is essential (even if it is tedious) for what I currently have in mind. The reason is that I wanted to analyze a particle traveling between two conducting metal plates, which surely seems to require them not to be spherical. This being the case, I'd like to construct a Stress-Energy Tensor describing the plates and go from there. I apologize for the lack of clarity.
Please see post #7. There is more to it if you want physically sensible results. The Israel junction conditions are what you apply to a boundary.
Ah, okay.
So for a (perfectly) conducting surface, are there known values or equations for the Stress Energy Tensor indices in question (pressure and Shear Stress/Momentum Flux)? Perhaps just a close approximation?
Sciencemaster said:
Ah, okay.
Presumably someone has done something like this, but I don't know the answer or a reference for it.
That's fine, I don't know either, of course. Thanks for your help though, I really appreciate it! Does anyone know what values we could use for these indices?
Well, the electric field inside the conductor is going to be zero. The field at the surface of the conductor, where the charges are, can be found by Gauss' law. The force on the surface charge will be the electric field at the surface multiplied by the charge, so the force density will be the charge density times the electric field. This will put the conductor under stress.
You'd need some material properties of the conductor to solve the for the distribution of stress. You might do using a non GR approach, but you could also do it using the equation ##\nabla_a T^{ab} = 0##. In general I would expect the division of the stress terms between radial tension and circumfrential tension would depend on the details of the material properties of the conductor, though I haven't attempted any serious analysis.
Weak field approximations would ignore the stress terms anyway, so there's no real reason to calculate them if you're doing a weak field analysis. But it's still not clear if that's what you're doing.
As I mentioned before, known materials can probably not support gravitationally significant tensions and pressures, but for such a case, I see no real need to use GR to analyze your problem. Newtonian physics should be good enough.
You'll also have to consider the exterior electric field as a source of the stress energy tensor, and hence gravitation. This will be a small effect, but it might be a reason to do a full GR analysis. Wiki has the formula for the stress-energy tensor of an electrromagnetic field , see https://en.wikipedia.org/w/index.php?title=Electromagnetic_stress–energy_tensor&oldid=1028734167. But it'll probably take some specialized knowledge to solve it.
I know that the gravitational effects probably won't be very significant in this problem (unless we choose to make the materials either very large or very massive), but I'd like to calculate them anyway even if they are very small. This being the case, I don't feel a weak-field approximation would be quite adequate.
If the material within the solid is an uncharged conductor, then I imagine the electromagnetic stress energy tensor goes to zero from inside, leaving just the description of the material itself. Since this is floating around in outer space, one could consider background radiation, however that's probably VERY negligible and so let's just say that the plate is uncharged, and as a result the electromagnetic stress energy tensor is 0 (I imagine). The bigger problem here is finding the stress energy tensor of an uncharged conductor.
So in order to create a metric out of two different regions, say, inside of the box and outside of the box, you have to make sure that K+ij (inside of box)-K-ij(outside of box) equals $$8\pi\cdot f(Tij)$$, where K+ij is a piecewise metric and Tij?
Essentially, this is just a constraint on the metric at the boundaries of the piecewise stress energy tensor?
I could be (and probably am) very wrong but that's what the paper (and some other sources) seemed to imply. Is this even remotely correct?
Why not? You don’t think particles can travel between spherical shells? That doesn’t make sense to me
Well I believe they can, but I believe that it would be more akin to what happens in laboratories, and it would be more like, well, particles moving between plates, rather than just motion between planets but on a very small scale. I imagine they are at least a tad different, metric-wise. Basically, I'd like to try something different.
  • #31
Sorry, that last message was rather confusing. What I meant to say was that a particle moving between two spheres seems very similar to its motion between two planets but on a much smaller scale. This is all well and good, but I'm more curious about the metric of a particle moving between two plates (in terms of the geodesics) since it is more akin to what one could visualize in a laboratory environment, and it isn't as commonly solved for.
  • #32
Yes, because the math is much more difficult. Anyway, good luck. I think you are “biting off more than you can chew”.
Likes romsofia
  • #33
I think you might very well be right, but i'd like to at least attempt it regardless.
  • #34
At any rate, am I thinking of the Israel Boundary Conditions correctly? Is there anything else special I have to do if I have a piecewise Stress-Energy Tensor (compared to one that is a single function)? Is there an easier way of dealing with the piecewise-ness?
  • #35
No, this is not correct. The conditions on the metric are indirect. From the metric on one side of boundary, you define a family of spacelike surfaces that approaches the boundary (foliation). Similarly for the metric for the other side of the boundary. The overall metric induces a 3-metric in each of these surfaces. Then, the first requirement is that the limit of induced metric from one side is the same as the limit of induced metric from the other side. Thus, the same intrinsic 3-geometry is implied on the surface where the overall combined metric is not differentiable.
Similarly, for each surface of the families, there is an extrinsic curvature tensor, K. These must also have well defined limits from each side. However, we don't require equality for these between the limits from both sides. Instead, the formula involving K equates the difference in limits from 2 sides to a stress energy expression, involving the "surface stress tensor". I am not really familiar with the details on this part, so I can't help you further. References are given in the paper I linked that should have more details.
