Piezoelectric Crystals: Constant Pressure & Electric Field
  • Thread starter Thread starter ScienceNerd36
    Crystals
A constant pressure on a piezoelectric crystal does initially generate an electric field, but the voltage quickly drops to zero due to the crystal's imperfect insulation and the need to extract current for measurement. When the crystal is deformed, a voltage builds up, causing free charges to rearrange and neutralize the voltage over time. This behavior highlights the transient nature of the electric field generated by piezoelectric materials under constant pressure. The discussion also introduces ferroelectric materials, which maintain a constant electric field without applied stress. Understanding these properties is essential for applications in electronics and materials science.
ScienceNerd36
If a constant pressure is kept on a piezoelectric crystal, will it continue to generate an electric field?
Actually, if you try this you will notice that the voltage drops back to zero quite quickly (seconds).
This is because the crystal is not a perfect insulator, and because you must extract some current to measure the voltage.
Yeah, when you deform a piezoelectric crystal, a voltage builds up. But that means that there is going to be a force acting on any free charges hanging around, which will try to rearrange themselves to cancel the voltage. So after a while the crystal should be neutral again.
Thanks for the help :)
You may be interested in Ferroelectric materials too. These have constant electric fields wihout the need to apply a stress.
You don't say. I'll be off to read up on them right now. Thanks :)
  • · Replies 0 ·
10K
