- #71
- 14,245
- 6,728
No, because n points (for each value of s) do not define u surface.Maaneli said:But aren't you introducing an absolute simultaneity surface
(a hypersurface across which all the particle positions are simultaneously defined, even at spacelike separations),
The parameter s is not time.Maaneli said:by virtue of the fact that you have to synchronize the initial positions of the particles at a common time s,
The synchronization changes with s.Maaneli said:and that this synchronization has to hold for all future s,
No, for two reasons. First, because n points do not define a surface uniquely. Second, because even these n points depend on the initial conditions at s=0.Maaneli said:And isn't that simultaneity surface unique?
"Fundamental Lorentz invariance" is not the same as constraints on dynamics imposed by the causal structure of Minkowski spacetime. At least, your terminology is not standard.Maaneli said:Also, the issue (in my view at least) is not whether the equations of motion are relativistically covariant, but whether the spacetime structure introduced is consistent with "fundamental Lorentz invariance" (which I take to mean the constraints on dynamics imposed by the causal structure of Minkowski spacetime).
With that I agree.Maaneli said:Also, when considering the possibility of nonequilibrium particle distributions in the multi-time Bohm-Dirac theory (assuming also for the moment that such a theory is in fact equivariant), I don't see anything in the synchronized trajectories approach that stops it from allowing superluminal signaling, as Valentini has demonstrated is possible with nonequilibrium particle distributions;
As I already explained, here you are using a non-standard terminology. Lorentz invariance is the principle that the laws of physics do not depend on the choice of the Lorentz frame of coordinates. That's all. Superluminal signaling is consistent with Lorentz invariance.Maaneli said:and superluminal signaling is the most explicit violation of fundamental Lorentz invariance that I can possibly think of.
See again the first Objection and Response in the attachment of post #109 in
https://www.physicsforums.com/showthread.php?t=354083
