Pinwheels for Wind turbines? In class, pinwheels proved most
In summary, during a class experiment, the pinwheel proved to be the most efficient shape in terms of generating current and voltage with a regular fan. However, the weight and friction of commercial turbines make this design impractical. Other sources such as books and publications can be consulted for alternative turbine designs.
sirrods
In class, of all the shapes we tested, the pinwheel won in the total amount of current and voltage, power generated. (used a regular fan and blew a bunch of different blade designs)
Question is, why don't we see pinwheels designs for turbines?
Where else can I look for turbines designs?
Thanks.
Pinwheels similar to the toys would be way too heavy. Inaddition, commercial turbines have low friction, so they can run faster - you get the same efficiency with a smaller number of slim blades, but slim blades can be made larger.
Various books and publications should discuss all the different designs.
sirrods said:
...of all the shapes we tested...
Which doesn't say much, just that your other shapes were even worse than a pin-wheel, for the given wind condition and gearing.
Related to Pinwheels for Wind turbines? In class, pinwheels proved most
1. What is the purpose of using pinwheels for wind turbines?
The purpose of using pinwheels for wind turbines is to capture the kinetic energy of the wind and convert it into electrical energy that can be used as a renewable source of power.
2. How do pinwheels increase the efficiency of wind turbines?
Pinwheels increase the efficiency of wind turbines by increasing the surface area that is exposed to the wind, allowing more wind to be captured and converted into energy. They also help to direct the wind towards the blades of the turbine, maximizing the energy production.
3. What is the difference between using pinwheels and traditional blades for wind turbines?
Pinwheels are smaller and have a simpler design compared to traditional blades for wind turbines. They also have a lower rotational speed, making them more efficient at capturing wind energy and reducing noise pollution.
4. Can pinwheels be used in all types of wind turbines?
Pinwheels can be used in both horizontal and vertical axis wind turbines. However, they are more commonly used in vertical axis turbines due to their smaller size and ability to capture wind from all directions without the need for a wind vane.
5. How do pinwheels affect the aesthetics of wind turbines?
Pinwheels can improve the aesthetics of wind turbines by giving them a more modern and streamlined look. They can also be painted in various colors, making them visually appealing and less intrusive in natural landscapes.
  • General Engineering
  • Other Physics Topics
11K
  • Mechanical Engineering
  • Electrical Engineering
