Playing with projection matrices: How did A^3 become the identity matrix?
Lifprasir
*new question, playing with projection matrix.
This is the first problem of our practice exam.
http://puu.sh/1jReL
And here's the solution.
http://puu.sh/1jRg3
The standard matrix has to be 2x2 to be compatible u v w, so this must be the reason why he limited the matrix to A (u v) = (v w) instead of A (u v w) = (v w u).
And then he used matrix properties to solve for A, and got it.
However what I don't understand is the part where it says "Observe that A^3u = u, A^3 u = v.
I've tried doing,
(u v) = D
(v w) = X
so, AD = X
A = XD^-1
Then I tried to reverse the observation by doing,
A^3u = u
A^3 = I
(XD^-1)(XD^-1)(XD^-1)=I, but that's as far as I'm able to go.
I really don't understand how he was able to see how A^3 was I..
Well I have a new question about the A(ATA)-1AT matrix.
http://puu.sh/1jXT6
I was able to show that BT was idempotent, but my manipulation was a bit different from the teacher for B2
Let B2 = (A(ATA)-1AT)(A(ATA)-1AT)
I did (AA-1(AT)-1AT)A(ATA)-1AT = IA(ATA)-1AT=A(ATA)-1AT=B
The teacher did it in another method and I don't think my method is correct because it doesn't make sense that B = I.
Hi Lifprasir! :smile:
(try using the X2 button just above the Reply box :wink:)
Because S3(u) = u, S3(v) = v :wink:
Ooooooooooooooooooooh. Thank you so much!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
