Please explain the reaction between Potassium carbonate and Magnesium
The discussion centers around a YouTube video demonstrating the reaction K2CO3 + Mg = K + C + MgO, raising questions about the displacement of potassium by magnesium. The key point is that the reaction is driven by thermodynamics, particularly the formation of stable magnesium oxide (MgO), which has a high enthalpy of formation and releases significant heat. While the reactivity series is mentioned, it is noted that thermodynamic stability is more critical in predicting the reaction's outcome. Participants clarify that magnesium's tendency to form stable oxides like MgO is what facilitates the reaction, emphasizing the importance of thermodynamic principles over simple reactivity comparisons.
lioric
TL;DR Summary
Why does Mg reduce K2CO3 even though K is higher in the reactivity series
I saw this video on YouTube, ()
which shows a person making potassium with the following reaction
I just don’t understand how Mg can displace K
I googled the reaction but couldn’t find much info on this reaction. Could someone give the name to this, or explain the chemistry behind it? There is a part where he uses KMnO4 and glycerin to start the reaction.
Thank you for your time.
Chemistry news on Phys.org
Haven't watched the whole video, but by the sound of it it is in a way similar to reducing oxides like it is commonly done in thermites.
Reactivity series is just part of the picture, and even not the most important one. What really matters when predicting reaction products is thermodynamics: ΔG = ΔH - TΔS (and sometimes kinetics, but that's not the case here). In this particular case reaction is probably driven by the MgO creation, such oxides are very stable and have very high enthalpy of formation (more or less making them produces a lot of heat).
Like always sir, you give a great explanation. Cannot count how many times you’ve helped out. Thank you so much. This was great.
Likes davenn, WWGD and BillTre
Hello Borek👋, so what you're saying is that the whole reaction is possible is because Mg which is an Alkali earth metal has an affinity to form oxides is that it?
More like "high stability of MgO is what drives the reaction".
Oooohh so since MgO is more stable than K2CO3 it tends to from MgO in this reaction.. Am i right?
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
