Please need someone to check this soon
  • Thread starter Thread starter Ion1776
The calculation for the change in potential energy of a 2.50 kg textbook lowered from 1.81 m to 1.50 m is correct, resulting in -7.595 Joules. The negative sign indicates a loss of potential energy, which is an important detail. To enhance clarity, it's recommended to include units in the final submission. Overall, the numbers used in the calculation are accurate. Providing additional context or explanation before submission would improve the presentation.
Ion1776
37
3. You lower a 2.50 kg textbook (remember when textbooks used to be made out of paper instead of being digital?) from a height of 1.81 m to 1.50 m. What is its change in potential energy?
1.50-1.81=-.31
(2.50kg)(9.80)(-.31)
=-7.595?
1.50-1.81=-.31
=-7.595?
Looks good. It is particularly good that you have minus sign, indicating that the book has lost potential energy. To be perfect, give the units.
The numbers are OK. I'd put in some units and some text before you turn it in.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
