Lambda96
- 223
- 75
- Homework Statement
- Plot ##g^{\epsilon}(x)## for ##\epsilon=1## , ##\epsilon=\frac{1}{2}## and ##\epsilon=\frac{1}{4}##
- Relevant Equations
- none
Hi,
I am not sure if I have solved the following task correctly
I did the plotting in mathematica and got the following
Would the plots be correct? What is meant by check for normalization, is the following meant?
For the approximation for ##\epsilon > 0##, does it mean that for the area of ## 0 < x < \epsilon## the area must be 1, so for the case ##\epsilon=1## the total area would be 1, the half for ## 0 < x < \epsilon## would then be ##\frac{1}{2}##, so the normalization constant should be 2?
