Point-Plane Electric Field Intensity
The discussion centers on the electric field intensity near the tip of an electrode in a point-plane geometry, described by the equation 2V / [r ln(4d/r)], where r is the tip radius, d is the spacing, and V is the voltage. Participants express confusion over the necessity of the tip radius in the equation, suggesting that a point tip could theoretically have a zero radius. However, it is acknowledged that a smaller radius increases field intensity due to greater divergence of the electric field. Comparisons are made to similar equations for wires and conducting spheres, indicating that the logarithmic term likely arises from the geometry of the tip. The original poster seeks references or derivations to support this relationship for their dissertation.
rpiengineer
Hi folks. I have read in several papers that the electric field intensity adjacent to the very tip of an electrode (the "point" in a point-plane geometry) surrounded by a dielectric medium is given by
2V / [r ln(4d/r)]
where r is the tip radius, d is the point-plane spacing, and V is the applied voltage. The papers I have read do not give a reference for this equation, however. Does anyone know where this equation comes from? I have thought about different ways one might derive this, but my models are lacking in their use of the electrode radius "r". The undergraduate and graduate textbooks I have available do not address this particular problem.
Many thanks in advance to anyone who can help me here !
Rob
That's kind of weird, why would you need a radius of a fine point tip? If it's a tip then you could assume it's just a point with 0 radius, but obviously that's not the case, so unless there is a trick but I don't see one right now, other than to use nasty double or triple integrals in polar coordinates. Or solve the laplace equation, but the boundary conditions would kill you.
I will try and look into it more.
Thanks so much. I know, having done endurance testing on polyethylene with embedded needles, that the tip radius is the most important factor in knowing the highest field intensity. I suppose this is because the smaller the radius, the more divergent the field, thus the higher the field intensity in the dielectric right next to the metal tip. We measure the tip radius of etched electrode needles before we insert them into molten polyethylene, then cool it to room temperature for testing. I just don't know how the many authors who make use of this relationship arrived at it. I would like to include the rationale - if not the entire derivation, which may be a bit long - in my dissertation.
Again, many many thanks for any help you can provide !
Rob
Not sure if this helps much, but the form of your solution is very similar to the fields around a wire of radius r parallel to a ground plane a distance d away. If the potential separating the wire and the plane is V, you get that the E-field at the wire is approximately:
E = V/(r*ln(2d/r)).
When I do it with a conducting sphere above the plane, I get
E = 2d*V/(r*(2d-r)),
however, which does not have the same form...
I agree, the logarithm must come from the circular tip shape somehow. Hmmmm...not sure what to think at this point.
Thanks for looking into it for me !
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
