Polar Coordinates Improper Integral Proofs
themadhatter1
(a) we define the improper integral (over the entire plane R2)
I=\int\int_{R^2}e^{-(x^2+y^2)}dA=\int_{-\infty}^{\infty}\int_{-\infty}^{\infty}e^{-(x^2+y^2)}dy dx=\lim_{a\rightarrow\infty}\int\int_{D_{a}} e^{-(x^2+y^2)} dA
where Da is the disk with radius a and center the origin. Show that
\int_{-\infty}^{\infty}\int_{-\infty}^{\infty}e^{-(x^2+y^2)}dA=\pi
(b)
An equilivent definition of the improper integral in part (a) is
\int\int_{R^2}e^{-(x^2+y^2)}dA=\lim_{a\rightarrow\infty}\int\int_{S_{a}} e^{-(x^2+y^2)} dA
where Sa is the square with vertices (\pm a,\pm a) Use this to show that
\int_{-\infty}^{\infty}e^{-x^2}dx\int_{-\infty}^{\infty}e^{-y^2}dy=\pi
(c) deduce that
\int_{-\infty}^{\infty}e^{-x^2}dx=\sqrt{\pi}
(d) By making the change of variable t=\sqrt{2}x. show that
\int_{-\infty}^{\infty}e^{\frac{-x^2}{2}}dx=\sqrt{2\pi}
I proved a by doing a change of variables into polar coordinates. However, I'm not quite sure how I would go about proving b.The idea that Sa is a square means I would be using Cartesian coordinates however, those 2 integrals don't have an antiderviative, what should I look at next?
update, I proved everything, however I'm not sure If my proof for b is what they're asking for. I said that
\int_{-\infty}^{\infty}e^{-x^2}dx\int_{-\infty}^{\infty}e^{-y^2}dy=\int_{-\infty}^{\infty}\int_{-\infty}^{\infty}e^{-(x^2+y^2)}dy dx
and since I had proved that the rhs of the equation equals pi it must be true that the left hand side of the equation equals pi as well. Dosen't a square of infinite dimensions have the same area as a polar rectangle where 0≤θ≤2∏ and 0≤r≤infinity. Does this satisfy the question being asked?
That's exactly what I did for part b. I have this assigned so I need some help on this problem as well.
I don't know how to do part c yet. I took the equation from b, and divided by the e^(-(y^2)) integral and all I would have to do is prove that that integral equals √∏. I tried to say that -y^2=x^2-r^2 so if you replace the e^(-(y^2)) integral with e^(x^2)/e^(r^2) (which I'm not sure if you can do), then idk I'm kinda stuck.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
